AC lines on a turbo integra?
Old Nov 17, 2003 | 03:41 PM
3 plus 1's Avatar
Default AC lines on a turbo integra?
Will I run into any problems with the AC lines (the high side line that runs in front of the radiator in particular) when I turbo the LS? I know I need to go 2.5" downpipe to keep the Compressor, but my main concerns are the lines that run along the passanger side (under the intake) and the high side line that runs in front of the radiator. Will the intercooler bump into it?
Old Nov 17, 2003 | 03:50 PM
Ben Huynh's Avatar
Default Re: AC lines on a turbo integra? (3 plus 1)
You'll have to remove that AC bracket and move it forward.
Old Nov 17, 2003 | 03:55 PM
Reilly's Avatar
Default Re: AC lines on a turbo integra? (ben@importparts.com)
Yep. Depends on the kit. My Rev Hard kit....no problems.
Old Nov 17, 2003 | 04:16 PM
AP-Signworks1's Avatar
You should be fine. The high side will run pretty close to the WG/manifold depending on setup, but I heat wrapped mine and it's almost touching, but no problems. The low side does run near anything that I can think of.
I had to wrap the lower line because the dump tube vents near it. And with the Fluidyne, the high side is a little cramped, but not bad. You do have to move the bracket some as mentioned.
Old Nov 17, 2003 | 06:02 PM
turbotypeR@SPEC's Avatar
25 Year Member
take off the upper braket and pull the lines foward.zippy tie them as far foward as posible.oh yeah, and you CAN have 3" downpipe with a/c.
Old Nov 17, 2003 | 06:22 PM
Full-Race Henry's Avatar
i pulled the line back with a ziptie and moved the condensor fan to the other side. here are some pics.
JSiRTO
Jul 6, 2007 02:27 PM
Nikoli
May 9, 2005 08:48 PM
1Bar GSR
Feb 9, 2005 07:04 AM
