A1000 with 850cc injectors?
Old Mar 12, 2012 | 03:01 PM
98_Milano_Teg's Avatar
Default A1000 with 850cc injectors?
My goal is to make right around 500 wheel horse power on e85.
With my current setup I was going to use a walbro 255 with my 850 injectors, but that wasn't enough.
So I am thinking about an a1000 fuel pump, and still keeping my 850 injectors, with -6AN lines. Will this combo still make 500 wheel HP?
Also, will I have to do an -6AN return line with the a1000?
Any suggestions on a better setup?
Thanks.
Old Mar 12, 2012 | 04:56 PM
sanman000719's Avatar
Default Re: A1000 with 850cc injectors?
dont see why not i made 650 on an a1000, and rc 1000's
Old Mar 13, 2012 | 04:48 AM
Muckman's Avatar
Moderator in Chief
Sanman that 650 was on gasoline, right?
When I switched to E85 I ran out of injector at 450whp with ID1000s. Two Walbro 255's cranked to 65psi base + 25psi.
Old Mar 13, 2012 | 05:10 AM
it was e85
base was 80psi/duty was 100%
Old Mar 13, 2012 | 05:18 AM
fmfkid250's Avatar
Originally Posted by sanman000719
it was e85
LOL, Ideal Conditions right?
I can't talk I made 644 on an a1000 and RC1200's Duty cycle was at 100% at 6500RPM
To answer the question. I would not buy an A1000 pump for anything. I would do twin 044's or a 255 feeding an 044. (Had an A1000 for years, It never failed but it sure sounded like it was going to fail in the near future)
I ran out of injector (880) on Gas at 500whp before. Getting there with E-85 your going to need a base for like 70-80. Again far from ideal!
Old Mar 13, 2012 | 05:28 AM
ideal is within the tuner and owner since they are the oens that make the decision.
now we need to remember that we are not at 100% duty all the time, and it will last like you said i used mine for 4 years this way and its still on the shelf in working order.
one pump fails it shut the motor down
2 pumps and one fails you go lean and lose an engine
rickoner
Jun 19, 2009 09:03 AM
ACTION JACTION
Jan 19, 2009 12:58 PM
b16b18
Sep 3, 2008 07:38 AM
Sir-Boost-Alot
Feb 4, 2006 12:00 PM
servion
Jan 20, 2004 02:16 PM
