95 Supercharged hatch project
Old Jun 25, 2012 | 06:12 AM
Sammie.07's Avatar
Icon4 95 Supercharged hatch project
Hey guys this is my first time posting so hang in there. I am curios of what you all think and open to suggestions. I had just recently came to the Honda world so this is my fist Honda i have ever owned along with my first Honda build. I have a good mechanical background but not with foreign.
Goal of 250+ WHP on pump gas
SO what I have so far is a 95 civic DX hatch with a d15b7.
My swap is
D16y8 block standard bore Z6 head
aqua monster 560cc injectors
Golden Eagle pro fuel rail
Vitaras with performance 2 point 0 custom length rods
Clegg engineering crank shaft with king bearings
ARP head studs and ARP 2000 rod bolts
Clutchmasters 6 puck ceramic disk and 2500# pressure plate
ex trans
4-2-1 header to 2.5 inch stainless pipe with test pipe to the tip (ebay kit)
P28
GSR fat 5s mirror pollished.
Most important thing is a bonneville ssei Eaton M62 supercharger thats has been rebuilt and built to run in CCW rotation and also has been ported.
Old Jun 25, 2012 | 09:26 AM
Sammie.07's Avatar
Default Re: 95 Supercharged hatch project
Old Jun 25, 2012 | 09:56 AM
MRGRIM's Avatar
R.I.P. Mark
good luck with the build
care to share pics of the charger porting ?
Old Jun 25, 2012 | 10:55 AM
Sammie.07's Avatar
I only took a 1/4 inch off each side and about 3/8 inch off the front to expose more of the rotor
this is a befor and after.
and here it is still on the cnc after it was cut
Old Jun 25, 2012 | 02:26 PM
Sammie.07's Avatar
Fuel rail just delivered
Old Jun 25, 2012 | 02:41 PM
dlaub25's Avatar
Nice work. It looks good. What type of manifold are you using?
Old Jun 25, 2012 | 07:50 PM
Spawne32's Avatar
Finally...someone cnc'ing a blower PROPERLY
Edit: Mrgrim is right, i was careless by neglecting to mention that step 2 of a proper cut there, is you have to angle the inside edge of the blower case to match the rotor curve. A straight vertical rise of the outlet is not conducive of smooth airflow out of the port.
Old Jun 25, 2012 | 08:08 PM
MRGRIM's Avatar
R.I.P. Mark
I would argue that but not going to thread jack
Old Jun 25, 2012 | 08:14 PM
Spawne32's Avatar
send me a pm then and explain
Old Jun 25, 2012 | 09:16 PM
Sammie.07's Avatar
Please explain, this is my first supercharger porting. Open to suggestions, there is a slight angle on the cut, hard to see but its there lol.
Old Jun 25, 2012 | 09:21 PM
Sammie.07's Avatar
I'm using my stock intake cutting it in half, I'm having a local shop stamp out an aluminum box I'm going to fit it and weld. Ill take pics its easier to explain with pics
Old Jun 25, 2012 | 09:22 PM
Spawne32's Avatar
Remember, runner length is not going to be as important here as is plenum volume. JRSC manifolds come with runners that are about 1" long.
Old Jun 25, 2012 | 10:40 PM
Sammie.07's Avatar
I'm going to have about 2 inch runners because my fuel rail is so big, but about the Plenum volume I am going to have to crunch some numbers to figure an efficient volume for it, I am hoping to run 15 to 18 psi ( hopefully)
Old Jun 26, 2012 | 12:30 AM
MRGRIM's Avatar
R.I.P. Mark
ok ill explain.. ( Black art / VooDoo supercharger porting)
1st you will align the rotors from the inlet
looking through the inlet align a left rotor tip at 60Deg as per the diagram
this is mesured from the center vertical and 60Deg through the center of the bearing
pic is not accurate just a drawing
then while in the position you can use either blu-tack or plasticine to hole the rotors still
now looking through the outlet you will see where the same rotor has aligned up to the opening.
You will also notice the the relation of the rotor to the opening is not straight but has a
gentle curve following this curve gives the porting shape for that side of the V outlet
Now where to open this up to is at 2mm away from the edge of the rotor to
housing meeting point ..when done it will leave you a lip with the rotor just tucked behind it
hiding
The reason for the 2mm is to allow room for a small shamfer or rounding of the sharp edges after port shape has be machined
the whole process is repeated again for the oposite rotor
after both have been done in this manner you have now maximised you port flow of the outlet...with all relavant results lower IAT, raised flow efficiency
I will explain the inlet in the next post
Old Jun 26, 2012 | 01:21 AM
MRGRIM's Avatar
R.I.P. Mark
to port the inlet ( Black art / VooDoo supercharger porting) cont...
looking at the inlet port as per the above pic you can see where the rotors meet the housing @ 60Deg
the main inlet porting is to smooth out any casting marks
further porting can be done at the bottom center of each half of the rotor swept area
as you can tell from my explaination there is not to much that can be done to the inlet
apart from a little mild porting and smoothing out casting faults
you can open up the inlet to the the S-tube further to allow flow
and match the ports
hope this helps
Old Jun 26, 2012 | 02:21 AM
Nailclipper's Avatar
very nice so far;-)
Old Jun 26, 2012 | 04:14 AM
Sammie.07's Avatar
and match the ports
hope this helps
It does thanks for the info, looks like I will be putting it back on the cnc hopefully today if I have time.
Old Jun 26, 2012 | 04:18 AM
MRGRIM's Avatar
R.I.P. Mark
when porting the biggest tip is look at it from the point of veiw of water
which way would you go and how ..what would slow you down
area mass volume should also be looked at re going from big to small
and vise versa, is there a slow point or turn
or somthing that you might get hung up on
Old Jun 27, 2012 | 07:40 AM
Sammie.07's Avatar
I was unable to get any more of an angle on there, I had already sealed it and put oil in it. So I will wait until after I run it to see it will do what I want, If not then I will change it. Thanks for the info tho.
Old Jun 27, 2012 | 02:02 PM
Sammie.07's Avatar
Last package arrived today !
Old Jun 27, 2012 | 02:04 PM
Sammie.07's Avatar
There is roughly $2000 worth of parts, now time to stop taking pics and assemble lol.
Old Jun 27, 2012 | 08:52 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
looks like a sweet little build.
Old Jun 27, 2012 | 11:46 PM
bigpunn421's Avatar
how do you build the supercharger to run counter clock wise?
sweet build too im am subscribing.
also how much boost do you plan on running? or blower rpm?
also why do you want lower compression?
Old Jun 28, 2012 | 01:01 AM
wantboost's Avatar
Who is Mr Robot?
How was it converted for ccw use? It looks like they flipped the rotors around and rotated the snout from the right side of the blower to the left. I have a y8 with rod knock that I've been debating about pulling apart to run a supercharger, however i would run it in place of the ac compressor as to facilitate the use of an intercooler. A company makes a phenolic intercooler kit that bolts to the outlet of the m62 but they aren't really cheap.
Old Jun 28, 2012 | 01:10 AM
MRGRIM's Avatar
R.I.P. Mark
To answer both the above questions
to make it CCW the only parts changed are as follows
the snout is flipped and the rotor drive gears inside are pulled off
and then they are swaped left to right
so the driven gear is now on the same side as the flipped snout
rotors stay as they where
sounds easy but it isnt
