557whp B16a Civic
Old Feb 18, 2006 | 03:03 PM
PrecisionH23a's Avatar
Default 557whp B16a Civic
I thought I would share this graph with you guys from Dave's daily driven set-up with ac/ps, etc. This was done at 25.5psi on pump gas with a built 81mm b16a. No detonation upon looking at the plugs for all you pump gas ****'s. Up top we are having a little problem with the boost controller holding constant boost. We will take care of this issue very soon.
I will be doing a few adjustments to the cams and putting race gas in later this week. We should be able to break 600whp easy with this set-up.
Old Feb 18, 2006 | 03:17 PM
boosted94cx's Avatar
* B A N N E D *
holy ****...550whp on a 1.6l with PUMP!?!??!?!?!??
Old Feb 18, 2006 | 03:18 PM
* B A N N E D *
Default Re: (s13-t)
what size turbo is this? it doesn't seem to ever level out from full boost...or, was the problem you mentioned keeping it from hitting a max psi before you let off?
Old Feb 18, 2006 | 03:26 PM
Oyvind Ryeng's Avatar
Default Re: (s13-t)
More details, please.
SpdFrk's Avatar
Default Re: 557whp B16a Civic (PrecisionH23a)
Thats impressive
Whats the setup?
Old Feb 18, 2006 | 03:27 PM
Synapse Motorsport's Avatar
Default Re: 557whp B16a Civic (SpdFrk)
I believe the turbo is a gt35r
spoon95eg's Avatar
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
Default Re: (s13-t)
God damn b16a rocksssss good numbers
Old Feb 18, 2006 | 03:34 PM
Default Re: (s13-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s13-t &raquo;</TD></TR><TR><TD CLASS="quote">it doesn't seem to ever level out from full boost...or, was the problem you mentioned keeping it from hitting a max psi before you let off?</TD></TR></TABLE>
Yea... the boost was fluctuating up top. Another problem we are having is when boost is kicking in. One pull the boost kicked in a lot sooner and produced about 60whp more throught the midrange compared to another run. I will have that problem also ironed out as well.
I don't think the owner wants me to disclose any further information.
Old Feb 18, 2006 | 03:37 PM
Default Re: (PrecisionH23a)
Nice job anthony, I talked to Jeff and he was super happy
Old Feb 18, 2006 | 03:47 PM
Meet07's Avatar
Default Re: (Synapse Motorsport)
Those numbers are crucial. so what kind of tunning did you use. Did you replace the map sensor??? and also what kind of injectors are you running to make 55 and some change???
those numbers are amazing. thats a nice goal that im trying to reach. And its possible
Old Feb 18, 2006 | 03:51 PM
FAST4DR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think the owner wants me to disclose any further information.</TD></TR></TABLE>
Seems the Blitz SBC unit has its idiosyncracies. We'll see 600 once we get a stiffer spring in the WG so we can turn it up just a hair more.
The power delivery is VERY linear.
Yes, GT35R.
Morgan - thanks for your help over the phone, as well!
B16 - a true wolf in sheeps clothing...LOL.
Old Feb 18, 2006 | 03:53 PM
FAST4DR's Avatar
Default Re: (Meet07)
1000 cc
Hondata S200 - need to upgrade to S300
3 Bar (need to upgrade there, too)
Amzingly, car is still very much streetable in 3rd and 4th gear pulls. 1st and 2nd are pretty worthless.
Old Feb 18, 2006 | 04:13 PM
Boostage's Avatar
Default Re: (FAST4DR)
is the c/r lower than 8.0?
Old Feb 18, 2006 | 04:31 PM
Turbocivic94's Avatar
Holy crap, what compression is this motor?
Old Feb 18, 2006 | 05:10 PM
...esteban's Avatar
Princess
Default Re: 557whp B16a Civic (Turbocivic94)
somethnigs fishy...There MUST be head work, or something, cause a friend of mine did 555 with race gas, 2.0 GSR, and more boost...Tuned by well known tuner on these boards as well...im waiting to see whats the mystery secret to getting that much power from a 1.6, not saying its not possible
Old Feb 18, 2006 | 05:49 PM
fmfkid250's Avatar
Default Re: 557whp B16a Civic (...Lost)
1 dyno doesnet equal the next dyno also...
Old Feb 18, 2006 | 06:00 PM
Suprdave's Avatar
Default Re: 557whp B16a Civic (fmfkid250)
That Car is creeping like a *****...
Old Feb 18, 2006 | 06:06 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ...Lost &raquo;</TD></TR><TR><TD CLASS="quote">somethnigs fishy...There MUST be head work, or something, cause a friend of mine did 555 with race gas, 2.0 GSR, and more boost...Tuned by well known tuner on these boards as well...im waiting to see whats the mystery secret to getting that much power from a 1.6, not saying its not possible </TD></TR></TABLE>
whats fishy? he never said stock head...
Blanket Jackson's Avatar
Dayum!!!!
Nice numbers on pump.
Old Feb 18, 2006 | 06:07 PM
alpha's Avatar
Default Re: 557whp B16a Civic (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">That Car is creeping like a *****...</TD></TR></TABLE>
First thing that came to mind when I saw the sheet. Peak torque at 8,XXXRPM.
Cant wait to see what it does when the boost issues are worked out
Old Feb 18, 2006 | 06:13 PM
Drew Peacock's Avatar
Default Re: 557whp B16a Civic (0x64)
What are the uncorrected numbers.
Old Feb 18, 2006 | 06:22 PM
adseguy's Avatar
Default Re: 557whp B16a Civic (turbozxi)
Subscribing. Hopefully we can find out the compression on this and a linear torque line in the future . Good luck with working out the Boost controller problems.
Old Feb 18, 2006 | 06:44 PM
FAST4DR's Avatar
Default Re: 557whp B16a Civic (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Subscribing. Hopefully we can find out the compression on this and a linear torque line in the future . Good luck with working out the Boost controller problems.</TD></TR></TABLE>
If anyone wants to chime in with hints on the Blitz SBC id, feel free.
There is no headwork on the head. ITR cams zeroed at TDC. We have NOT played with the cam gears, yet.
Compression is 9.1:1.
I think the reason we are creeping is due to GAIN setting on the bc. Again, anyone care to share settings, please do so. I'd like to see 600 on pump.
Modified by FAST4DR at 8:41 PM 2/18/2006
Old Feb 18, 2006 | 06:46 PM
alpha's Avatar
Default Re: 557whp B16a Civic (FAST4DR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FAST4DR &raquo;</TD></TR><TR><TD CLASS="quote">
I assume you are using the manual mode? If not change to that. If so what are your settings? What size spring in the wastegate?
Old Feb 18, 2006 | 06:57 PM
Suprdave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FAST4DR &raquo;</TD></TR><TR><TD CLASS="quote">I'd like to see 600 on pump.</TD></TR></TABLE>
You must be beggin' for the Gods to give you melted pistons or pounded out rod bearings.
