550cc RCs on h22...max??
what whp do you think i will be at max duty cycle with my rc 550s
i have a 255lph pump, and im getting an aeromotive fpr as well..
it is an 89mm h22 with t3/4...
i might have to order 880s if these will be maxed... im looking for high 300s maybe 400 whp
anyone acheived 375+ whp on 550cc???
Modified by Boosted 01 SH at 7:52 PM 2/9/2005
I used the calculations on http://www.rceng.com and for 550's at 85% duty cycle they'll only be good for around 300 HP. 650's are good for about 350 HP and 750's are good for about 400 HP.
However for those above calculations I used .6 as the BSFC. If you do the math for BSFC for your setup, it comes out to .5 BSFC.
So at .6 BSFC & 85% duty cycle
550 - 300 HP
650 - 350 HP
750 - 400 HP
And at .5 BSFC & 85% duty cycle
550 - 355 HP
650 - 420 HP
750 - 485 HP
550 - 300 HP
650 - 350 HP
750 - 400 HP
550 - 355 HP
650 - 420 HP
750 - 485 HP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted 01 SH »</TD></TR><TR><TD CLASS="quote">tweaking fuel pressure a bit might be able to squeeze a little more too, i think, but im not sure.. </TD></TR></TABLE>
I did the math for that too:
Say we are going from a fuel pressure of 43 up to 53 PSI on a set of 550 injectors.
(new FP / old FP) square root = A
multiply A by the injectors size that you are raising FP on = new flow rate
(53 / 43) square root = 1.1102 x 550cc = 610cc (new flow rate)
