550cc injector fitment prob
alright so the RC550's i have do not fit like the oem ones. i do have the rings that RC provided, but there is no way in hell the OEM plastic ring can go on and fit with the provided RC ones...
any help would be appreciated!
Same problem I had. The RC rubber rings were too big and the injector wouldn't fit in the fuel rail.
All I did was take the RC injector ring off and put on a pencil. Got some sandpaper and sanded it down to the size of the OEM injector ring.
Worked like a charm!
DAN
DAN
Stick the injectors in the hole as far as they will go. Then put on the fuel rail. Then slowly and evenly bolt down the fuel rail. It is necessary to do it slowly and evenly. You can also take off some of the excess material but I've always had success just doing the slowly and evenly method.
bolting them down slowly worked for me a couple times, i find that lubing the rings with petroleum jelly helps alot and it leaks/evaporates away after a few heat cycles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 »</TD></TR><TR><TD CLASS="quote">bolting them down slowly worked for me a couple times, i find that lubing the rings with petroleum jelly helps alot and it leaks/evaporates away after a few heat cycles.</TD></TR></TABLE>
yup this works for me...putting a little bit of oil around the outside of the ring also helped me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the smart guy up there somewhere »</TD></TR><TR><TD CLASS="quote"> Stick the injectors in the hole as far as they will go. Then put on the fuel rail. Then slowly and evenly bolt down the fuel rail. It is necessary to do it slowly and evenly. You can also take off some of the excess material but I've always had success just doing the slowly and evenly method. </TD></TR></TABLE>
lube it up and follow those instructions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype »</TD></TR><TR><TD CLASS="quote">Stick the injectors in the hole as far as they will go. Then put on the fuel rail. Then slowly and evenly bolt down the fuel rail. It is necessary to do it slowly and evenly. You can also take off some of the excess material but I've always had success just doing the slowly and evenly method.</TD></TR></TABLE>
that's what i did with my RC550's. i don't even think i did it evenly. lol and i didn't use any lube.
Don't forget some oili for lubrication.
thanks for t5he replies guys. i am going to go ahead and lube them up and shove them bitches in there and then tighten it until i know that i wont get a leak...
thanks again
thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict »</TD></TR><TR><TD CLASS="quote">Be careful not to overtighten and snap the studs.</TD></TR></TABLE>
good call...happened to me
