450's with resistor box?
ok so i have never used the dsm 450 cc injectors with the resistor box allways used plug and play injectors with turbo builds.. but im doing another gsr turbo build woohoo... now i got a gsr harness with the splice for the resistor box.. so what do i need just the blue top injectors and a box and its all plug and play or what.. sumone help me out, never messed with this..
i really really hate to say this, since ive never said it before, but wow, see the red text at the top that says "search"... its REALLY not that hard to find info on wiring in a resistor box, and what u need to do so...
i have a child already, he is the only one i spoon-feed...
u need the injectors, the resistor box, a voltmeter, some solder, and some shrinktubing...
if the resistor box is properly wired in, you dont need to do a thing. maybe dremel a tab from the injectors, swap a few rubber o rings. plug & play.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarvis199 »</TD></TR><TR><TD CLASS="quote">i really really hate to say this, since ive never said it before, but wow, see the red text at the top that says "search"... its REALLY not that hard to find info on wiring in a resistor box, and what u need to do so...
yeah ok thanks for the help... that was sarcasm by the way...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote">if the resistor box is properly wired in, you dont need to do a thing. maybe dremel a tab from the injectors, swap a few rubber o rings. plug & play. </TD></TR></TABLE>
thanks bro thats what i thought just wanted to make sure...
