440 saturated or 500+ p&h ?
i'm ditching my various bandaids and going with a PMS for my supercharged prelude (2000 sh.)
current setup is a vafc, jr ems (btc + map converter etc) and cartech 2025 fmu. i want to get rid of the fmu also, which means my 370cc injectors probably won't cut it. when i was on the dyno, it took about 90psi of fuel to get 12.5:1 on the 370s, but we strongly suspect that has a lot to do with various crappy electronics. does everyone think 440s would be enough? the car is/was putting down around 220whp, but i'm planning on upping the boost a bit. i don't want to go bigger if i can avoid it because of the resistor pack needed to run the bigger injecters (RC doesn't offer saturated injectors bigger than 440cc.) http://images.zeroforum.com/smile/emsad.gif the formulas at the rc site are useful, but my proposed setup is right at the edge. thanks in advance. |
Re: 440 saturated or 500+ p&h ? (schwett)
Hmmm, sounds like the 440's may be hitting their upper limits with your setup. If you up the boost from here, which I suspect you will having the PMS, then you may want to consider using the resistor pack with some larger peak-and-hold injectors. I don't advise running over 80-85% duty cycle on the injectors, and I think with your setup you may be either right there or just above that. Hope this helps.
ttt
anyone else? 440cc for 250whp on an h22? |
On Hondata's website it says that 440cc at 80% duty cycle and 40Psi fuel press can support up tp 280whp. http://images.zeroforum.com/smile/emthup.gif
Re: 440 saturated or 500+ p&h ? (97CivicFerio)
i wonder what that's based on... seems like if it took my car 370cc at 85% dc to get 220whp something is wrong. maybe ridding myself of all the crap electronics will help, but dc is dc!
i believe RC does carry larger saturated injectors. look towards the bottom of this page. http://www.rceng.com/prices.htm
Re: 440 saturated or 500+ p&h ? (racerxadam)
i spoke with them, they don't, and are "in the process of updating their web site." http://images.zeroforum.com/smile/emsad.gif
i believe RC does carry larger saturated injectors. look towards the bottom of this page. http://www.rceng.com/prices.htm |
