400hp is the goal
I wanted a 3" DP but it wouldnt fit with the a/c compressor in the way (i wanted to keep a/c). I think I will defintely get the intake manifold and larger intercooler with bigger injectors(750cc)......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy »</TD></TR><TR><TD CLASS="quote">i made 400 with a drag turbo kit and intercooler. turbo was an SC-61 and a 2.5 dp and exhaust so it can be done</TD></TR></TABLE>
its an SC-61
its an SC-61
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrdthry911 »</TD></TR><TR><TD CLASS="quote">it seems you dont want to change your manifold, but is there anyway to get a full 3" downpipe in there? thats gonna be holding you back quite a bit</TD></TR></TABLE>
shouldnt be bad, i made up a 3 inch dp for a friend of mines greddy kit...
my idle is at around 1000rpm, a little high but im also using 1000cc injectors. i personally dont have any idle problems. stays pretty constant 1200 at startup setting down to 1k.
imo there are other upgrades to get before a TB. spend the money elsewhere....ac mani/3" downpipe.
3" Dp, 3" exhaust, 750cc injectors, and a nice manifold are key.
simple receipe below
GSR - Sleeved 83mm bore - CP 9:1 pistons
Peak Performance H Beam rods w/ARP rod bolts
P72 Main & Rod bearings - OEM HONDA PINK
Cometic Head Gasket
ARP Hear Studs
Peak Performance/Blox intake manifold
750cc injectors, sx 1:1 FPR, resistor box, 255lph fuel pump
peak performance manifold
tial 38mm wg
Garret 60-1 .63a/r
3" downpipe
3" exhaust
FMIC - ebay special 24-12-3
greddy profec b spec ii boost controller
oil pressure, boost, egt gauge
convert to OBD1 if needed
Neptune engine mangement (tuner required)
Cometic Head Gasket
ARP Hear Studs
tial 38mm wg
Garret 60-1 .63a/r
3" downpipe
3" exhaust
do you honestly believe that 1000cc would be better than 750cc to achieving the 400hp mark?
The tuner can on the hondata burn adjust the idle as best as possible to achieve a good idle.
