300whp on stock internals?
if u expect to buy all those upgrades, u could take HALF that money and buy a 700$ piston and rod set.
Being a stronger motor will help u get more power than any of those upgrades.
you have to use vtec oem pistons but they will make your compression higher and then your really going to start blowning up things. so you best bet is to get forge pistons low compression vtec ones. so you can't use any oem pistons. unless you spray nitrous with high compression b16 or type-r pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneracer »</TD></TR><TR><TD CLASS="quote">you have to use vtec oem pistons but they will make your compression higher and then your really going to start blowning up things. so you best bet is to get forge pistons low compression vtec ones. so you can't use any oem pistons. unless you spray nitrous with high compression b16 or type-r pistons. </TD></TR></TABLE>
I HAVE 300WHP AND I DRIVE MY CAR EVERY DAY AND HAVE NO PROBLEMS.
BOOSTING 11LBS...... THE ONLY THING IS, I AM TUNED WITH HONDATA S300 AND ON 100 OCTANE GAS.
THAT WILL BE THE DIFFERENCE
AND ALSO DEPENDS ON YOUR TUNER.........................
ok so u guess im gonna have to uy a set of pistons and eagle rods, how r the srp pistons? or the vitara pistons? i see alot of d series guys running vitaras, do they make them for b series?
Get forged internals (I don't care about your budget
)...otherwise your motor won't be lasting long
And SRP is just another branch of JE...JE is more "all-out" pistons while SRP is for more street use.
I went ahead and tossed in a set of Eagle rods and 9.5:1 SRP pistons in my B18C1 while the motor was out...no turbo yet
My god. Please, please stop spreading absolutely horrible misinformation.
To the OP, yes you can make 350whp. Stock LS block, Vtec head, efficient turbo setup, ARP headstuds, lots of fuel, and GOOD TUNING.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highmilehatch »</TD></TR><TR><TD CLASS="quote">
To the OP, yes you can make 350whp. Stock LS block, Vtec head, efficient turbo setup, ARP headstuds, lots of fuel, and GOOD TUNING.</TD></TR></TABLE>
hit the nail on the head
to some of you nuts, you do know that with higher compression it does mean you can technically make better power right?
btw if you go forged, save everyone a headache, dont waste the $$ on JE, go wiseco. Cheaper, and I know of guys who would rather run stock over JE for boost because of bad experiences
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moosepoop21 »</TD></TR><TR><TD CLASS="quote">ok so u guess im gonna have to uy a set of pistons and eagle rods, how r the srp pistons? or the vitara pistons? i see alot of d series guys running vitaras, do they make them for b series?</TD></TR></TABLE>
Vitara pistons are pistons from a Suzuki Vitara, which is the same bore as a d-series. They will not work in a b-series.
