3 bar map sensor wiring question.
Old Jan 12, 2007 | 10:45 AM
92redhatch's Avatar
Default 3 bar map sensor wiring question.
I want to know how to connect my 3 bar map sensor. My harness is a 1995 civic ex harness and i know the 3 bar map sensor has 3 wires coming out of the connector. I wanted to know how to connect my factory 3 wires to the 3 bar map sensor wires. Does the left wire go connected to the left wire? does the middle wire go connected to the middle wire? And does the right wire go connected to the right wire?
Thanks
Old Jan 12, 2007 | 11:08 AM
92redhatch's Avatar
i tried that already find me a thread that shows the wiring.
Thanks.
Old Jan 12, 2007 | 11:11 AM
92redhatch's Avatar
ill check it out thanks. The diagram is for a GM 3 bar map sensor right?
Old Jan 12, 2007 | 11:14 AM
ladysman's Avatar
Default Re: (92redhatch)
http://www.hondata.com/tech3barmap.html
Old Jan 12, 2007 | 11:25 AM
92redhatch's Avatar
thank now i have another question on the top or the map sensor where it say GM what numbers should be on a 3 bar map sensor.
Mine says 466
and under C B A
it says 749 7316
and on the bottom side by the vacuum it says AA1-5
Thanks,
Old Jan 12, 2007 | 01:25 PM
Boosted B6teen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">thank now i have another question on the top or the map sensor where it say GM what numbers should be on a 3 bar map sensor.
Mine says 466
and under C B A
it says 749 7316
Thanks,</TD></TR></TABLE>
Sounds right to me
Actually, post up a picture if you wanna be %100 sure
EX-T
Oct 5, 2008 10:28 AM
redlsvtec4door
Nov 4, 2007 08:57 AM
Topdawgg
Jun 27, 2006 03:57 PM
nick-vti
Aug 10, 2004 09:27 PM
