3 bar Map sensor Problem?
Old Jul 7, 2003 | 01:53 PM
CiViC SiR's Avatar
Default 3 bar Map sensor Problem?
i installed upgraded turbo chip to work with 3 bar map sensor, but i still didnt got the map sensor so i started my car with stock map sensor and missing link but the car starts to cut out at 4000rpm is that normal?
and i'm getting code 3 (Map Sensor Deactivated)
Old Jul 7, 2003 | 02:22 PM
CiViC SiR's Avatar
Default Re: 3 bar Map sensor Problem? (CiViC SiR)
any help
Old Jul 7, 2003 | 02:26 PM
IloveNewt's Avatar
make sure u wired it right to start off. Did u solder it or use liek butt connectors...
Old Jul 7, 2003 | 02:30 PM
CiViC SiR's Avatar
Default Re: 3 bar Map sensor Problem? (MordecaiPSI)
i didnt installed the 3 bar map sensor i'm trying to start the car with its original map. will the car start or i have to wait for the 3 bar map sensor?
Old Jul 7, 2003 | 02:39 PM
TurboCX's Avatar
You will definitely have to wait for the 3bar map.
Old Jul 7, 2003 | 02:55 PM
BROOD's Avatar
I think you already diagnosed your problem.......get the 3bar MAP sensor in there the ECM is programed for it. It expects to see a signal from a 3bar MAP not the oem MAP. It is confused.
young geezer
Aug 1, 2009 12:44 PM
KRWTEK1
May 28, 2007 12:32 AM
EJ8 GSR-T
Mar 29, 2007 06:48 PM
turbolshatch
Feb 2, 2006 06:06 AM
