... 3-bar map sensor with hondata
Old Feb 13, 2003 | 04:27 AM
1.8T_EG's Avatar
Default ... 3-bar map sensor with hondata
... i just wanna confirm... this is the correct map sensor and it will work with hondata 100%... i did a search and read that some gm 3-bar map sensors will not work with hondata... lemme know... thanks...
http://www.Gmpartsdirect.com
gm 3 bar map sensor # 16040749 ($49.08)
harness: #12085502
Old Feb 13, 2003 | 06:11 AM
badCRX's Avatar
New User
Default Re: ... 3-bar map sensor with hondata (1.8T_EG)
Not sure if that is the right one or not. Make sure when you wire it up your Hondata readings say roughly 1.5-1.6 for MAP when its not running, but the car is in the 2 position.
I would recommend getting one from a local parts store, so you can return it if its not the right one.
[Modified by badCRX, 9:12 AM 2/13/2003]
Old Feb 13, 2003 | 08:27 PM
1.8T_EG's Avatar
Default Re: ... 3-bar map sensor with hondata (badCRX)
can anyone confirm?... thanks...
Old Feb 13, 2003 | 10:51 PM
inspyral's Avatar
My 3BAR map says 16040749 on it. It's not installed though:
Old Feb 14, 2003 | 07:30 AM
95c1v1cs1's Avatar
Default Re: ... 3-bar map sensor with hondata (inspyral)
I am interested too...
Old Feb 14, 2003 | 08:04 AM
integraracer94's Avatar
I want to know also
Old Feb 14, 2003 | 08:28 AM
B18EG6's Avatar
Default Re: ... 3-bar map sensor with hondata (integraracer94)
http://www.gmpartsdirect.com PN: 16040749
^thats what i have saved in my neverending internet ctrl+v page
Old Feb 14, 2003 | 08:31 AM
alpha's Avatar
2K_TEG posted a good reference post.
<snip>
3 BAR MAP sensor – If you are or are planning on running over 11 psi you need a different MAP sensor. The OEM Honda MAP sensor will not work. Pick up a 3 BAR GM MAP sensor from http://www.gmpartsdirect.com PN: 16040749
</snip>
https://honda-tech.com/zerothread?id=353920
Old Feb 14, 2003 | 10:12 AM
swrdply400mrelay's Avatar
I saw the post on this before, but can't find it. Though I did save the part numbers and your numbers match what I got down.
harness: #12085502
b20turbocivic
Aug 12, 2010 07:06 PM
lucidvtec
Jul 11, 2005 11:51 PM
R THIS
Dec 14, 2002 03:39 PM
Anubyss
Oct 18, 2002 05:35 AM
