3 Bar Hondata Map sensor what GM is it from
Old Nov 15, 2002 | 07:07 PM
Camshaft's Avatar
Default 3 Bar Hondata Map sensor what GM is it from
Does any one have on of these ? whats the gm part number
or what GM car did it come from
thanks
Cam
Old Nov 15, 2002 | 07:13 PM
Flamenco-T's Avatar
Default Re: 3 Bar Hondata Map sensor what GM is it from (Camshaft)
the sensor part nuumber is 16040749
the harness is 12085502
hth
Old Nov 15, 2002 | 07:17 PM
Camshaft's Avatar
Default Re: 3 Bar Hondata Map sensor what GM is it from (Flamenco-T)
thanks man....
What Gm car is it from ?
Super thanks
Old Nov 15, 2002 | 07:49 PM
Mr. Vapor's Avatar
im guessing a Grand Nash or Typhoon/syclone?
Old Nov 15, 2002 | 07:52 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: 3 Bar Hondata Map sensor what GM is it from (NYb16)
as far as i know, just about any GM V8 or whatever back in the mid to late eightys had a 3 bar MAP, my cousin has a tuned port 350 in his camaro with a 3 bar... i almost stole that thing just so i wouldn't have to buy one
Old Nov 16, 2002 | 09:28 AM
VaporTrail's Avatar
New User
89 turbo trans am.
Old Nov 16, 2002 | 09:32 AM
kidkutz's Avatar
Default Re: 3 Bar Hondata Map sensor what GM is it from (VaporTrail)
89 turbo trans am.
Old Nov 16, 2002 | 09:35 AM
Speed PHreak's Avatar
89 turbo trans am.
Word 16.5lbs of boost stock
Old Nov 16, 2002 | 09:58 AM
Camshaft's Avatar
Default Re: 3 Bar Hondata Map sensor what GM is it from (Speed PHreak)
That thing had 16 pounds of BOOST ???
Crazzzzzzyyyyy
Thanks guys.... !!!!
Called the dealer in Canada 135.00 CND from dealer ripe off....
[Modified by Camshaft, 10:58 AM 11/16/2002]
[Modified by Camshaft, 11:05 AM 11/16/2002]
Old Nov 16, 2002 | 01:16 PM
CRVRX's Avatar
Which had a 2Bar map from the factory?
Thanks...
Old Nov 16, 2002 | 01:20 PM
Camshaft's Avatar
Default Re: 3 Bar Hondata Map sensor what GM is it from (CRVRX)
I called my local gm dealer and the part number is from a 20th aniver. trans am
As well I punched the number in a search engine and got a number of web sites....
With GM info saying it was a 3 bar map sensor
Forget what other GM's use a 2 bar, typhoo or what ever and something else.
Old Nov 16, 2002 | 01:22 PM
Camshaft's Avatar
Best price I found was from this place
BUT they hose you on the shipping BIG TIME!!!!!!
17 frigging bucks to ship a connector and map sensor what does it come in a 12x12x12 box ?????
ARG
GMPartsDirect.com
c/o Flow Chevrolet L.L.C.
Attn: Order# 35360
1400 S. Stratford rd.
Winston-Salem N.C. 27103
gmpartsdirect.com.
Category: Computer Control Sensors
Description: CONNECTOR
Min.Qty: 1
Unit Price: $14.38
Quantity: 1
Ext.Price: $14.38
Core Charge: $0.00
Description: SENSOR AS
Min.Qty: 1
Unit Price: $49.08
Quantity: 1
Ext.Price: $49.08
Core Charge: $0.00
SUB TOTAL: $63.46
SHIPPING: $17.77
integra-modder's Avatar
http://www.gmpartsdirect.com/
Sensor is # 16040749
Harness is # 12085502
there you go...
Old Nov 16, 2002 | 01:23 PM
ahahah, beat me to it...
Old Nov 16, 2002 | 01:37 PM
Default Re: 3 Bar Hondata Map sensor what GM is it from (integra-modder)
1 Bar GM part # 2503679
standard part # AS-5
Pretty much any normally aspirated TBI GM car, plus plenty of others
2 Bar GM part # 16009886
Wells part # SU-129
standard part # AS-4
91-93 GMC Syclone & Typhoon 4.3 turbo
87-90 Pontiac Sunbird Turbo 2.0
84-86 Sunbird (actually any J-car) turbo 1.8
3 Bar GM part # 16040749
Baro GM part # 1600683
Has a piece of foam over the pressure port.
100 Kpa, 4.9V 90 Kpa, 4.4V 80 Kpa, 3.8V 70 Kpa, 3.3V 60 Kpa, 2.7V 50 Kpa, 2.2V 40 Kpa, 1.7V 30 Kpa, 1.1V 20 Kpa, 0.6V 10 Kpa, 0.3V
Old Nov 16, 2002 | 01:41 PM
http://www.diy-efi.org/gmecm/compone...o/sensors.html
11psiGSR
Jul 5, 2023 09:36 PM
JDM97R
Jul 20, 2008 11:29 PM
Foozball26
Oct 13, 2002 03:03 PM
Darin D.
May 14, 2002 03:28 PM
gs-turbo
Mar 23, 2002 01:08 PM
