(#2)How much Boost can a stock H22 handle??
(OG) question...I want togo turbo... but idk if for now I could just put on a kit that I have sit'n in my room... could I run 5psi. with out doing damage to the motor daliy driving...?? (Y/N) (details) I should of been a little more specific.... I have a T3/T4 turbo. Yes I do plan on tuning it when I have it mounted. The motor is about to hit 140,*** miles in the next few days an it runs good... w/an 8lb Fly W. and a stg.2 clutch an light GT3's an 2 or 3 other modes I can take out JDM GSRs in a EK, build LS Tegs, an GSRs w/ Type R in-ni's... an no I'm not bragging just give an idea of where I sit.... an still, not happy... I just want to have very quick Prelude thats all... Im just looking for help an or options... an thanX for the Help to those who reply...
Re: (#2)How much Boost can a stock H22 handle??
Firsth thing Id do is a compression/leakdown test. From there if you get back a good reading then I would turbo it. Also give us a hp goal not a psi level.
should be alright but remember its not the amount of boost a motor will handle it all depends on what kind of power your planning on making. Boost means nothing we have threads like this every day its not how much boost a motor will hold its how much power tuned a motor will handle. untuned you could blow it on 3 lb's and i think the record on stock H series is deep in the 500hp range if im not mistaken. My buddy had a stock H in his car ran 10psi on a holeset HX35 hybrid made 308whp at 8 lbs on a dyno ran fine no problems until he up'd it to 18psi and he broke all his rings lands and it was tuned but a holeset is a lot different than a ebay 57 trim so ya
I would say 5-7 Psi tuned correctly will be fine . If thats under or around 280-300WHP
But the H22 Ring lands are known to be week and could break even at that . |
Originally Posted by Silva Bullit DC4
(Post 40524684)
LOL, why did you make three threads, homie?
https://honda-tech.com/forums/showthread.php?t=2674186 https://honda-tech.com/forums/showthread.php?t=2674189 |
<400 and your a pussy :O)
h22 record is over 500 whp.
its all in the tuning, and the condition of your motor pre-boost. good motor, good tuner, good power |
Sticky worthy FTW!!! |
