i have had my car turboed for about one month now and it doesnt seem like it pulls as hard as my friends turboed b18 so i go out to the track last ngiht and it was my first time racing on a track but i run a 16.5 with a 2.9 60 then i turned the boost up to 12 then i ran a 16.3 with a 3.0 60
i have all mandrel 2.5 in intake piping but off of the turbo i have a radiator hose elbow then i have garrett t3t4 57 trim .63 ar housing 2.5 in dp all the way back(im in the process of finishing my exhaust so its an striaght 2.5 off the dp with no cat or resinator for fuel i have lucas 440 cc injectors and im using the uberchip tial wastgate a log manfold and its on a stock b18a1
if you have any ideas let me know
chris
chris
Thats outright horrible. You should be almost trapping that without being boosted. You sure your charge pipes are connected? Are you getting a reading on your boost gauge?
something or several things are majorly wrong
are you throwing codes?
do you get spark and fuel in all of the cylinders?
charge pipes connected? you have a boost gauge?
my friend had a very shitty set-up. jg race cams, gn turbo & i/c, 450cc injectors, log manifold, shitdyne brass ecu, b18a w/ls tranyy etc. he ran a 14.3 on 17" rims, but his trap speed was 104mph (at 8 psi, i believe). his set up was utter **** and he still ran 104mph. i have no clue what is wrong with your car, but with a 93mph trap, i would say your turbo ain't working. holla back
HELLO,GOOD MORNIN'
are you sure you didn't run a mile track.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul_Vang »</TD></TR><TR><TD CLASS="quote">thos 60' ft times are horrendous
</TD></TR></TABLE>Honda-Tech Member
yeah those 60 ft times suck
i ran a 15.0 with a stock b16a in my eg with a shitty 2.35 60 ft time
just practice launching
and get some sticky tires
something is definately wrong! I'm running 15.0@93mph with an LS motor in my EG hatch NA....with just bolt-ons. I'd have it checked out.
Did you run that 1/4 in reverse?!
something is wrong big time..those times are almost identical to my stock D16A6 Si times
I was gonnna say your turbo is seized but since your seeing boost that is not the problem so now I got my money on the clutch,My guess is that your clutch is toast.
I was gonnna say your turbo is seized but since your seeing boost that is not the problem so now I got my money on the clutch,My guess is that your clutch is toast. Thread Starter
no codes when driving although when i honk the horn i think it shorts itself out it sounds really starnge and when i do that the check engine light will come onand the rpms drop about 500 or so
it says a solid ten or twelve psi when im boosting im not sure im getting park in all cylinders though i will check
thanks
thanks
i did a comp test and it was about 150 all thw way across with full throttle
any more suggestions
Is your car an auto? 3.0 60' is truly some bad driving if it's 5-speed.
his car is a manual but the tree went straight greenhe does need to work on his driving yes it sucks horrible but it was his first time and i he has 17 in rims
we still cant figure out whats going on so any help is appreciated
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darylfiend11 »</TD></TR><TR><TD CLASS="quote">anyone have any other ideas?</TD></TR></TABLE>
First get some tires or learn to drive. I've had some horrible launches and even just messed up on purpose and never got anything close to a 2.5 60ft and you ran a half a second slower than that! Also 150 on all 4 cly is very low, does your car burn any oil?
no it doesnt burn any oil that i am aware of should i do a leak down test?
all four cyclinders are getting spark some one else said that my clutch could be bad is there any special way to test and see if my clutch is bad i know i suck horrible at driving but i am learning and i dont know if it matters but the light went from stage to green
thanks
thanks
My friend just went 16.03 in a stock CRX, 1.6 non vtec. There's something defiently wrong.
ok we get the point the kid is a newbie driver,, theres no need to rip his ****,,,,hes asking for help,, ok first check the clutch, i had a similiar incident where i was actually spinning my clutch bad as hell, because in the staging lanes i was just ****** around and playin with my clutch (for example inching up in line, riding the clutch) anyways if your clutch heats up then unless its a dual diaphram,, it looses grip, then next i would check the leakdown in each cylinder,,,what are your plugs gapped to? is your car detonating at all? is it hesitating? what kind of tires are you on? also look at your 60ft times this way here>>> if you pulled a 2.0 60ft you would have prob ran 2 seconds faster netting you some 14.0-14.3 timeslips,,, generally every tenth you loose in the 60ft , looses 2 tenths in your time up top, but i cant explain your MPH though,,,, that might be the clutch if its stock, check those things out though,
ok thanks very much i will check those things out and yeah i will definatly be practicing on my 60 times but is there any way you can check out to see if a clutch it bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scatuli »</TD></TR><TR><TD CLASS="quote">then i turned the boost up to 12... and its on a stock b18a1
oh yeah no detonation at all but my car when i am just driving it normaly is good up to 2900 rpms then it will hesitate but then smooth itself out my af gauge says leanbut oi can boost with it like that and it is fine i am using one step colder plugs ngk 6 i think which are gapped to .05 and i have some kumho ecsta which i will be changing shortly
you can tell if it's going bad if it doesn't grab right away.
