11.5:1 compression am i able to boost?
Old Jul 11, 2004 | 03:10 PM
95lsvteg's Avatar
Default 11.5:1 compression am i able to boost?
i'm interested in getting turbo but i'm not sure how high is to high for compression. i have ls vtec with 11.5:1 srp pistons and eagle rods , type r oil and water pump. am i able to boost if so how much?
Old Jul 11, 2004 | 03:12 PM
tegasaurus's Avatar
Default Re: 11.5:1 compression am i able to boost? (95lsvteg)
no... w/ forged internals you can boost the hell out of it. just tune it.
now i'll get back to my thread, which was created 1 minute earlier than yours.
Old Jul 11, 2004 | 03:16 PM
hulkhb's Avatar
Default Re: 11.5:1 compression am i able to boost? (tegasaurus)
i would go over 6-7 psi
Old Jul 11, 2004 | 03:47 PM
TurboJesse
Guest
Posts: n/a
Default Re: 11.5:1 compression am i able to boost? (hulkhb)
throw a headgasket on to lower comp.
Old Jul 11, 2004 | 03:53 PM
MachAF's Avatar
Detonation will be a problem on that high of compression.
Old Jul 11, 2004 | 04:29 PM
95lsvteg's Avatar
Default Re: 11.5:1 compression am i able to boost? (Mpir3)
what headgasket would work
Old Jul 11, 2004 | 04:31 PM
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lsvteg &raquo;</TD></TR><TR><TD CLASS="quote">what headgasket would work </TD></TR></TABLE>
cometic turbo head gasket (should lower your compression to about 10.9:1)
Old Jul 11, 2004 | 04:33 PM
95lsvteg's Avatar
that's not bad what turbo setup would work best with my setup?
Old Jul 11, 2004 | 07:16 PM
pngfolife's Avatar
Are you trying to run on pump gas? If not just get some ERC and you should be good up to one bar.
Old Jul 11, 2004 | 09:00 PM
DLB1994's Avatar
Default Re: 11.5:1 compression am i able to boost? (pngfolife)
get a inline pro headgasket and it will drop it to 10.5:1 much safer on pump gas and still make good power
Old Jul 12, 2004 | 01:20 AM
95lsvteg's Avatar
Default Re: 11.5:1 compression am i able to boost? (DLB1994)
yes i will be using pump gas. just not sure what size turbo i should get. this is going to be my first turbo project. so..
ChrisYuki
Aug 16, 2015 08:19 PM
99siRACER
Jan 3, 2012 12:20 AM
RTst92
Mar 5, 2006 01:56 PM
RooskiGSR
Feb 28, 2005 04:23 PM
dtrtw
Sep 16, 2004 04:34 PM
