100 octance to e85...how big injector needed?
made 237 whp (dyno dynamics) on 100 octane (no tune on pump gas)
fuel system consists of the following:
dual walbro 255 pumps
precision 525 cc injectors
golden eagle fuel rail
full fuel lines -8 for a feed and -6 for return
tuned for a base 65 psi
tuned by hondata s300...i dont have it avail to me at the moment to see duty cycle.
just wondering if i have enough injector or need larger injectors to switch to e85.
thanks in advance! any help appreciated!
I am no expert on this, but a buddy of mine had to up the size of his injectors when making his switch. Forgive me for not remembering the exact size he needed. but as i have been reading that a "simple" calculation would be to multiply your current injector size by 1.47
This was done by multiplying the lb/hour by 1.74
So your calculation would be 50 lb/hr for your current 525cc injector multiplied by 1.47 which would equal 770cc injectors. Please note that this is what i found in a little bit of research. You still will want to consult with your tuner.
Based on your dual pumps, i would say that you are covered in that area. That should be more than enough to keep lph good.
you need 30% more fuel when using e85 to make the same power. so depending on your injector duty cycle now you can get an idea of how much more they got in them.
Not looking to change any other variables at this time other than tuning for the switch in fuel...Just whatever the gain is
From 100 octane to e85...motor is n/a
If my 525s are big enough I'm leaving the setup as is...
Right now 100 octane is 6.99 a gallon. If I can gain a few % in power and save a few dollars a gallon (yeah I know e85 uses more fuel) I'm happy
E85 does require more fuel.
On dsm's I did around 250 to the wheels those are 450's I think.
I would switch to e85 and get some bigger injectors just to be safe. It reduces knock also and is rated at 105 octane so theres benifits all over. The only downside is if its available at more than one station in your area. Theres only two in mine at about 35 miles both ways from me. But nothing a 10 gallon gas can cant fix.
Also I wouldnt take knownworldwide's advice I read a couple of his post and decided not to read em anymore see what im gettin at
Just a thought though. If you do upgrade your injectors don't limit yourself from furthur growth. If you see yourself boosting in the future you might as well go with 1000's or bigger depending on your HP goals. I'd hate to see you go to 750-770's then in 6 months from now needing to upgrade again. Everyone's build plans change. Again IMHO.
I was going to get tuned on E85 and my tuner said that I was fine with 440's with my setup. So I know it can be done with 440's+.
My Fuel setup:
Walbro 255
Stock injectors
AEM fuel rail
Pretty much the same fuel lines
Again my tuner just wanted me to upgrade my injectors. I was going to go 440's and he said that was fine I just decided to wait till I have the money for 1000's because I plan to boost.
My Fuel setup:
Walbro 255
Stock injectors
AEM fuel rail
