1/2 Core Radiator on a Teg?
Old Mar 14, 2006 | 06:38 PM
Home Wrecker's Avatar
Default 1/2 Core Radiator on a Teg?
What kind of cooling problems will i run into, if I were to use a civic half radiator on a boosted teg? I see it working on lots of cars but if mine is a daily driver the engine will get hot on long rides. It's not boosted yet but I will probably need the room. Is it a realistic solution as a space saver. Also, if I were to use the 1/2 core with a 12 inch slim fan what would be the minimum cfm on the fan required to keep things from overheating? Thanx.
Old Mar 14, 2006 | 06:48 PM
jdm'dc2sc61's Avatar
Default Re: 1/2 Core Radiator on a Teg? (StephenSadowski)
people are gonna tell you to search because its been covered many times.
there are people that run the normal half-size without any problems. i ran one, but it still overheated so i ended up buying a PWR aluminum half-size, and it hasn't overheated since. i'd recommend getting an aluminum one just to be on the safe side. it's a real space saver as well. as for the fan, i'm not sure.
Old Mar 14, 2006 | 08:21 PM
808 NA1's Avatar
Think about this. Why would an Integra with a 1/2 size run hotter than all the civics running a 1/2 size? They both have the same motor. Just because its an Integra makes no difference.
Old Mar 14, 2006 | 08:24 PM
onemanlan's Avatar
Default Re: 1/2 Core Radiator on a Teg? (808 DB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808 DB8 &raquo;</TD></TR><TR><TD CLASS="quote">Think about this. Why would an Integra with a 1/2 size run hotter than all the civics running a 1/2 size? They both have the same motor. Just because its an Integra makes no difference. </TD></TR></TABLE>
Err no? Unless you're talking about a swap.
Old Mar 14, 2006 | 08:25 PM
808 NA1's Avatar
Default Re: 1/2 Core Radiator on a Teg? (onemanlan)
Well, yeah thats what I was talking about. B/H/K series Integra vs B/H/K series civic.
Old Mar 14, 2006 | 08:26 PM
no2unenolife's Avatar
i've been running a del sol vtec radiator and its holding up well.
Old Mar 29, 2006 | 12:14 PM
mootsman's Avatar
I have a single core 1/2 sized radiator on a boosted GSR....no problems thus far. I run a 50/50 mix in the summer in Memphis, TN where temps can get over 100 in the summer. Not sure how accurate the stock water temp gauge is, but mine has never even made it to the half way point...
just my .02
Old Mar 29, 2006 | 12:58 PM
chubz0r's Avatar
Default Re: 1/2 Core Radiator on a Teg? (mootsman)
good info.. i never thought baout it that way. i might have to get myself a civic half size then.
bitchin camaro
Jul 10, 2005 09:04 PM
desiromeo812
Jun 29, 2005 01:44 PM
zangiefisgod
Feb 12, 2004 09:36 AM
X2BOARD
Apr 10, 2003 07:05 AM
