01 prelude turbo..hits vtec feels like is slows then picks back up
Like the tile says. It will rip all the way to vtec hit then it throws you foward a bit..then it starts to pull again. my buddy who tuned said he notice anything but i can feel it when i drive
t3/t4 60 trim hermsfab log mani tail 38mm 3indp with 3exhaust |
sorry for my bad ingrimish https://honda-tech.com/forums/images...s/emsmilep.gif
anyone
Re: (DrivinVtec)
needs more tuning it seems.
If ur tuner cant feel it and u can, put it on a dyno. |
Re: (93supercoupe)
what are u tuned on?
definetly in the tuning...
your tuner probably didnt get the fuel tables right for vtec... IMO, id be lookin for a new tuner.. this guy doesnt know what hes doing... did you have a wideband in? or on the dyno? what is the A/F like? around 4500-6000 |
Re: (Topdawgg)
it was tunned with crome an yes on wide band. street tuned
Re: (DrivinVtec)
so what is the A/F lookin like in those areas?
you must have been in the car when he was tuning |
Re: (Topdawgg)
maybe he set VTEC too early. but preludes usually like VTEC set really low
Re: (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 »</TD></TR><TR><TD CLASS="quote">maybe he set VTEC too early. but preludes usually like VTEC set really low</TD></TR></TABLE>
it would totally depend on the setup!! injectors, spool time/turbo size.... its something that has to be played with |
Re: (Topdawgg)
this was while back. i dont go in vtec very often. idk
get it on the dyno, or get another wideband in it.... its a tuning problem, id bet money on it
its about to get rebuild with a new bottom end. ill just wont hit vtec in it to be safe.
oh..thanks for the help
Re: (DrivinVtec)
get it on the dyno, why rip it apart if theres nothing wrong but just needs better tuning?
Re: (Topdawgg)
want more boost. only 7lbs now. looking for 14-20psi
with a good tune, no reason why you couldnt do it on a stock block....
but its not a psi level, its HP that you set your goals at.. |
Re: 01 prelude turbo..hits vtec feels like is slows then picks back up (DrivinVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec »</TD></TR><TR><TD CLASS="quote">Like the tile says. It will rip all the way to vtec hit then it throws you foward a bit..then it starts to pull again. my buddy who tuned said he notice anything but i can feel it when i drive
t3/t4 60 trim hermsfab log mani tail 38mm 3indp with 3exhaust</TD></TR></TABLE> Like everyone said, its a tuning issue. |
Re: (Topdawgg)
these h22 arent the best for boost. Id like a saftey point when make a street car. shooting close to 400whp https://honda-tech.com/forums/images/smilies/emthup.gif
what are u running for fuel?
Re: (DrivinVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec »</TD></TR><TR><TD CLASS="quote">these h22 arent the best for boost. </TD></TR></TABLE>
says who? theres a local one here that ran 2 years on a 100 shot of nitrous, beat on at the track constantly... and now has 430whp for 2 years in a row also beat on at the track... stock h22....11.6 @ 119 mph a couple weeks ago... |
Re: (Topdawgg)
do a search
Re: (DrivinVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec »</TD></TR><TR><TD CLASS="quote">do a search</TD></TR></TABLE>
i think you are the one that needs a search... any motor is only as good as the tuning and quality of the turbo setup... built or not... what year is your h22? whats stamped on it? |
Re: (DrivinVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec »</TD></TR><TR><TD CLASS="quote">these h22 arent the best for boost.</TD></TR></TABLE>
this has been covered numerous times but if u say so! |
Re: (Topdawgg)
It a h22a4 open deck block. The stock piston are the weak part of this motor.
