"mtber" Tuned Single Cam !!! Dyno plot Inside !!!
Old Sep 10, 2006 | 03:53 PM
rainmanEK's Avatar
big strong guy
Default "mtber" Tuned Single Cam !!! Dyno plot Inside !!!
I did this work for a 18 year old kid whom is a good friend
The Setup was on a 99' Civic EX SOHC Vtec
Bone stock Internals
Spoolin Performance Log Manifold
Spoolin Performance 2.5" DP and Dump Tube
3" Kteller Exhaust (NO CAT)
Garret T3 Super 60 Turbo from SP
Ebay Intercooler 16"/6"/3" Bar And Plate
Spoolin Perfromance CNC I/C Tubing
"mtber" Tune on Chrome
Kenji ECU conversion Harness
440cc Injectors from SP
John "Mtber" did a Awesome Job, The Car idles like stock and it has a very Smooth power band! Thanks John
I would like to thank My Father Mike, JD the owner, Kenji, and John "mtber"
Here is the Dyno Plot for 9psi
It also Made 250whp @ 11psi and 210whp @7psi
Eric
Old Sep 10, 2006 | 03:57 PM
Iceman05's Avatar
nice #s on a stock sohc, but get ready for head lift issues
Old Sep 10, 2006 | 04:24 PM
xsi-t's Avatar
Default Re: "mtber" Tuned Single Cam !!! Dyno plot Inside !!! (rainmanEK)
John and I talked about this car on the phone today. Great work John
-- 0x64
Old Sep 10, 2006 | 04:29 PM
TypeSLO's Avatar
good numbers. wow, someone from Lutz, FL. first time seeing that.
Old Sep 10, 2006 | 05:13 PM
civicsi940's Avatar
very impressive
Old Sep 10, 2006 | 05:22 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (civicsi940)
That's efficient as hell!
Old Sep 10, 2006 | 05:29 PM
SC61HB's Avatar
At what rpm were you hitting full boost?
xsi-t's Avatar
Default Re: (boostincoupe)
Great work John!!!
-Chris
(BoostedCivicSedan)
Old Sep 10, 2006 | 05:34 PM
97turboteg's Avatar
Default Re: "mtber" Tuned Single Cam !!! Dyno plot Inside !!! (TypeSLO)
why head lift issues?
Old Sep 10, 2006 | 05:59 PM
rainmanEK's Avatar
big strong guy
Default Re: "mtber" Tuned Single Cam !!! Dyno plot Inside !!! (SC61HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SC61HB &raquo;</TD></TR><TR><TD CLASS="quote">At what rpm were you hitting full boost?</TD></TR></TABLE>
A tad over 3,000 rpm And the Turbo hits pretty hard and Fast
Eric
Old Sep 10, 2006 | 06:16 PM
nowtype's Avatar
That torque curve is retarded looking.
Old Sep 10, 2006 | 08:07 PM
ketchup!'s Avatar
Default Re: "mtber" Tuned Single Cam !!! Dyno plot Inside !!! (nowtype)
you have the exact setup i want
Old Sep 10, 2006 | 08:12 PM
project dc2's Avatar
great numbers !
Old Sep 10, 2006 | 08:15 PM
SOHC_MShue's Avatar
Default Re: (Iceman05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iceman05 &raquo;</TD></TR><TR><TD CLASS="quote">nice #s on a stock sohc, but get ready for head lift issues</TD></TR></TABLE>
Dont talk if you dont know what your talking about. They dont lift heads with the proper timing.
Old Sep 10, 2006 | 08:18 PM
Hella_Fresh's Avatar
Default Re: (SOHC_MShue)
250whp @ 11psi !!!!
damn. thats way good!
Old Sep 10, 2006 | 08:33 PM
AbitAvenger's Avatar
Default Re: (sXekid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sXekid &raquo;</TD></TR><TR><TD CLASS="quote">250whp @ 11psi !!!!
damn. thats way good! </TD></TR></TABLE>
Old Sep 10, 2006 | 08:52 PM
Kelly.'s Avatar
I've quit using this account
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">Dont talk if you dont know what your talking about. They dont lift heads with the proper timing.</TD></TR></TABLE>
x10
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">That torque curve is retarded looking.</TD></TR></TABLE>
compared to what?
Old Sep 10, 2006 | 08:58 PM
mtber's Avatar
Its actually Phearable.net tuned but same thing :-)
Nice job on the turbo kit Eric
The car made great numbers per psi with intake temps of over 100 deg F.
Overall besides messing with the MBC and Injector orings the tune went good.
With another hour or so on the dyno I could have probably made the tq curve look a little nicer
Modified by mtber at 1:15 AM 9/11/2006
Old Sep 10, 2006 | 09:43 PM
racinskittle's Avatar
What kind of boost controller is that? Homemade? If so, got directions? Looks a little better than the one i got.
Old Sep 10, 2006 | 10:34 PM
HeedLessInc's Avatar
Default Re: "mtber" Tuned Single Cam !!! Dyno plot Inside !!! (racinskittle)
Great numbers on stock internals
Old Sep 11, 2006 | 01:21 AM
Ex Member's Avatar
Default Re: "mtber" Tuned Single Cam !!! Dyno plot Inside !!! (HeedLessInc)
very effecient for that setup
Old Sep 11, 2006 | 01:03 PM
rainmanEK's Avatar
big strong guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">What kind of boost controller is that? Homemade? If so, got directions? Looks a little better than the one i got.</TD></TR></TABLE>
Voodoo MBC
We had to cut the spring to get it to work right though....
Eric
Old Sep 11, 2006 | 01:09 PM
nowtype's Avatar
Default Re: (Kelly.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kelly. &raquo;</TD></TR><TR><TD CLASS="quote">
compared to what?</TD></TR></TABLE>
Compared to normal torque curves? It seems like the turbo is making full boost around 3800rpm, then the torque flattens out and then jumps up, then kind of gradually rises. Its retarded looking. I would have guessed it was internally WG'd but I'm surprised it isn't. Maybe its a vtec engagement issue or just didn't dial in the timing/fueling correctly. Either way, the torque curve looks retarded.
Old Sep 11, 2006 | 01:21 PM
EK k kay's Avatar
Default Re: (nowtype)
Wow great numbers! Setup is like mine, but with a less restrictive exhaust than mine.
Old Sep 11, 2006 | 02:29 PM
Civicman86's Avatar
great job! Glad to see there are still alot of people pushing the limits of the d series.
How much timing at full boost?
