EF B series
Old May 31, 2011 | 03:23 PM
xpwex's Avatar
Default EF B series
Innovative Civic/CRX 88-91 B-series + Hydraulic Transmission Mount set.
I bought this installed it but never ran the car.
Comes with the 3 mounts.
Rear DA T bracket drilled out.
Engine side front mount (Da)
and hydro to cable bracket.
The last image is how is sits on the EF
200 firm No trades
sold as is.
Also a set of cut and welded GSR tranny linkages (They were put through a grinder and painted recently)
The Shifter one measures 37" and the other measures 34" from center hole to center hole.
It fit my Sedan please check your ride first.
Comes with shifter and rubbers also comes with NIB
Bitch Pin and tranny O gasket
65 firm no trades
I also have a set of Civic Si Axles with the ABS but I knocked the rings out
It fit on my 1989 Civic LX Sedan I do not know about your car please do the research
On axle has Zero miles and the other is used no rubber cracks.
45 firm for both No trades
)))I do not have the mid shaft any longer only the tow outer(((
Not pictured two slim fans that will be needed for a b series ef swap.
20 firm for both new. No trades
Location JAX
Old Jun 1, 2011 | 01:35 PM
xpwex's Avatar
Default Re: EF B series
60 for linkages now!!
Old Jun 3, 2011 | 05:07 AM
xpwex's Avatar
Lower Prices!
Old Jun 4, 2011 | 12:21 PM
xpwex's Avatar
Bump Pm me prices let's work something out!
Old Jun 7, 2011 | 11:33 AM
xpwex's Avatar
Even cheaper prices!!!! Hit me up
Old Jun 11, 2011 | 04:55 PM
xpwex's Avatar
Still up peeps bump for the hook up
xpwex
Feb 7, 2012 04:49 PM
NipponRacing
Northwest (Sales)
May 31, 2007 02:01 AM
red civic standard
Feb 21, 2007 04:16 AM
-CP-
Oct 7, 2003 06:53 AM
