Custom CTR Geared transmission
Item: Custom CTR geared transmission
Price: $1000.00 FIRM!!!
Contact: Pm or (561)275-0087
Item Description: I am selling a custom built transmission with the following set-up.
-(EM1) S4c casing
-00 CTR Gears and factory LSD
-98 ITR 4.7 final drive
Photos:
-(EM1) S4c casing
Photos:
The 4.7final drive came from the '98 spec jdm ITR only.
Also a b16,ctr, an itr all have the same 1-5 gearing except the jam 98 spec itr which uses a GSR 4-5.
The CTR and 96-97 spec ITR have the same gearing and 4.4 final drive, the 98+ spec had the same 1-3 gears, but the 4th and 5th were gsr gears cause of the 4.7 final drive making it more bearable on highway. By using the 4.7 final drive from a 98+ spec with the CTR gears he made the 4th and 5th shorter. Essentially this transmission is better than a 98+ spec in terms of rpm drop in 4th and 5th.
