1995 Acura Integra K-Swap Partout
Old Aug 25, 2016 | 06:48 AM
T4nkz's Avatar
Default 1995 Acura Integra K-Swap Partout
Parting out my K-Swapped 1995 Acura Integra. THE ENGINE IS BEING SOLD AS A FULL ALL YOU NEED SWAP TO JUST KEY THE KEY AND DRIVE! Most parts are high quality and a lot of them are slightly used. Prices are set in stone, and I do not need any trades. Contact me below, or send me a message via Facebook for any questions or pictures. Will ship if you pay for shipping. Appreciate it.
Looking to sell the full turnkey swap, which is a K24A2 motor with an RSX Type S Transmission. Undamaged and healthy motor from an Automatic 04-06 TSX, swapped back in March. Less than 1k miles added to it since the swap. Serious buyers only, the swap is still in the car and will be pulled if and when purchased, giving you a chance to test drive it. The following parts included:
K24a2
K20 RSX Type S Transmission
Hondata V3 ECU
Wireworx Tucked Harness
Hybrid Racing Swap Conversion Kit
KTuned Fuel Rail
KTuned Fuel Pressure Regulator
KTuned Fuel Pressure Gauge
KTuned Inline Fuel Filter
Steel Braided Fuel Lines with –an Fittings
KTuned K24 Intake Manifold Adapter
KTuned K24 Upper Coolant Housing
KTuned Heater Core Delete
KTuned Adjustable EP3 Pulley Kit
KTuned Coil Pack Cover
KTuned RBC Adapter
RBC Intake Manifold Ported to 70mm
BLOX Throttle Body 72mm
DC Sports Swap Exhaust Manifold
Thermal R&D 3 Inch Exhaust with Resonator
Hybrid Racing Cold Air Intake
Hybrid Racing No Cut Shift Box
Hybrid Racing Shifter Cables
Hybrid Racing Radiator Hose
Innovative Engine Mounts
KOYO full size Aluminum radiator with BLOX Slim Fans
RDX 440s
32mm RSX Axles
Stage 4 Comp Clutch
Fidanza Lightweight Flywheel
Full Turnkey - $6000
Suspension:
Ground control coilovers – Sell with Shell
Kyb struts – Sell with Shell
Ktuned adjustable traction bar - $250
BNIB BLOX Racing Front Camber Kit w/ Comp Sliding Ball Joint - $60 for both.
BNIB Skunk2 pro series rear camber kit - $160
BNIB Buddy club extended lower ball joints - $150
BNIB Energy suspension trailing arm bushings - $25
Brakes:
Wilwood 4-piston calipers / pads - $350
Slotted / cross drilled rotors (front) $140
Wheels / tires
Advan RG (first gen) 17x7 1/2, 4x100
Durun 215/40/17 tires
Together - $1100 or $900 plus steelies
Exterior:
Authentic Mugen Front Bumper - $1500
95’ Acura Integra Shell with One Year Old Paint (Doesn’t come with the Mugen Bumper) - $2300 ONLY AFTER THE SWAP IS SOLD
If you need pictures just ask. https://orlando.craigslist.org/pts/5733178360.html I'm sure some of y'all have seen me at shows.
Old Aug 25, 2016 | 04:55 PM
toyomatt84's Avatar
Sanji
Default Re: 1995 Acura Integra K-Swap Partout
Please see here: Honda-Tech - Announcements in Forum : Honda-Tech Marketplace
JayWest
Feb 27, 2012 04:10 AM
Solidecho
Honda Civic (2001 - 2005)
16
Nov 21, 2010 11:29 PM
k20eg48
Mar 4, 2010 08:13 AM
89D15CRXDX
Oct 22, 2006 02:29 PM
