What is the purpose of Tunerview
Old Oct 4, 2010 | 12:57 PM
averyvm's Avatar
Default What is the purpose of Tunerview
What up people,
Does tunerview totally replace having to use a laptop when changing table values. Or is it simply an extended gauge cluster that allows you to see more readouts than you would normally see with a stock gauge cluster?
Old Oct 4, 2010 | 01:33 PM
HRTuning's Avatar
Default Re: What is the purpose of Tunerview
It's a display, it's always been a display, and has never been put out there as anything other than a display. It's to show you the data you want to see in real-time.
If it ever modifies anything, it will only be for NepTune RTP.
