Using old tune on new build
Old Apr 5, 2025 | 12:41 PM
blue6gen's Avatar
Default Using old tune on new build
Okay. So, let me start off by saying I completely understand That every engine is different and should have its own tune and I will definitely be doing that.
Last year I had a turbo sohc vtec f22b1 in an accord. Ebay .57 turbo, rdx injectors, aem wideband and running on a p28 w/Cobra RTP emulator. Was remote tuned on 10 psi. I currently have a Del sol with a d16y8. I'm running the same turbo, injectors, wideband and P28 ecu but with the Snake emulator rather than a Cobra. The tuner of the old set up started with a Z6/Y8 base map because we couldn't find the f22b1 map for some reason. So here is my question. Can I load up my old tune to my new set up just to do some shake down running? Just to track down querks ,boost leaks,clutch strength ect....
I just want to minimize any issues when i pay for the custom tuning session.
Old Apr 5, 2025 | 12:45 PM
theYBLEGAL's Avatar
Loved
Default Re: Using old tune on new build
Those motors will flow air very differently so i would say no, too far off.
The base doesn't make it any more or less compatible, they were simply the starting numbers, which is all different now for the f22.
Old Apr 6, 2025 | 08:33 AM
blue6gen's Avatar
Ahhhh gotcha. Makes sense. Thanks
ShBoxAccord
Engine Management and Tuning
Mar 17, 2021 02:27 AM
stopsayingJDM
Aug 13, 2012 04:19 PM
beginmyhonda
11
Dec 19, 2011 04:21 PM
1LowSol
Feb 8, 2009 10:34 PM
Crimson_Tide
Mar 15, 2006 02:49 PM
