single wire 02 sensor ? (EG)
Old Sep 5, 2010 | 05:50 PM
dumpeddhatchh's Avatar
Default single wire 02 sensor ? (EG)
ok so i have a check engine light after i did my wiring. so i checked the codes & told me i have to check the 02 sensor. ok i dont have 1 lol so i looked for the plug on my engin harness. its only 1 wire ! i have a 95 dx hatch. but i bought another engine harness off a CX "supposedly" so im trying to figure out what year harness this is so i can buy the 02 sensor. as i said before its only 1 wire, not 4 . is this possible ?
Old Sep 5, 2010 | 05:51 PM
Default Re: single wire 02 sensor ? (EG)
please help !
Old Sep 10, 2010 | 06:08 PM
JSPECSIR's Avatar
yes, lotsa cars only have 1 wire o2's
Old Sep 11, 2010 | 01:09 PM
Gunmetal_B20_Hatch's Avatar
CX harness will have 1 wire O2
All others besideds VX will have 4-wire
Old Sep 11, 2010 | 05:32 PM
GhostAccord's Avatar
Yes the (92-95) CX had a 1 wire O2. However, If you are running a DX (P06) OBD1 ECU you will need to install a 4 wire O2 to fix the O2 codes. Or swap out the CX harness.
Old Sep 13, 2010 | 01:08 PM
gen2integra2001's Avatar
i have a complete obd1 d16z6 engine harness if your trying to swap from the 1 wire 02 sensor to the 4 wire 02 sensor.
but if your going to stick with the 1 wire 02 then you will need the corrosponding ecu aswell so you wont get the cel's for the 02.
johnxjohn26
Apr 22, 2007 08:07 PM
1sikhatch
27
Feb 10, 2006 07:43 AM
Jmunk
Feb 6, 2005 08:28 AM
civicmatt
Jun 22, 2003 07:27 PM
civicracer1993
Feb 11, 2003 06:35 PM
