s300 datalogging
If you want to run a switch for the on-board logging all you have to do is choose an input in the program that you want to run the switch to.
I would suggest using the A/C input. It is a grounded input. So run one side of the switch to chassis ground and the other side of the switch to pin B5 on the OBD1 ECU.
When you flick the switch and it grounds the pin at the ecu it will enable on-board logging.
DC2*Integra
Audio / Security / Video
Apr 6, 2010 08:28 AM
type Gendy
Aug 31, 2005 06:09 PM
