Problem using DSM injectors with Crome
Old Sep 28, 2013 | 10:58 PM
  #26
flip_ep's Avatar
Originally Posted by hysteria411
Thanks guys. I've got my wideband now so I'll mess around with that and see what I can do. I really appreciate all of your help with everything.
What did you ended up getting for the offset for 450cc dsm blue top? And do you apply fuel multiplier then fuel tools or fuel tools the. Fuel multiplier? Because if I do fuel multiplier it cuts the base map values in almost half .533 then if I use fuel tools the. Fuel multiplier it doesn't touch the map at all?
Old Sep 30, 2013 | 06:12 PM
  #27
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: Problem using DSM injectors with Crome
You were probably sold the 270cc injectors from a non-turbo FWD talon, which is why you're running lean on the 450 preset.
Check the serial number on the side; if it doesn't say 450, go punch that bastard in his throat.
cjself14
Apr 28, 2014 05:11 AM
nus_dogg
May 20, 2012 07:26 PM
ZERO COOL
Jul 15, 2002 05:36 PM
threatcon13
Jan 31, 2002 08:32 AM
