Problem in AEM EMS - Engine load stuck on 35psi
Old Feb 23, 2009 | 08:56 PM
magefa's Avatar
Default Problem in AEM EMS - Engine load stuck on 35psi
Hey guys,
i'm running a B16 turbo.
with AEM EMS 30-1040 , GM 3bar MAP
when i turn the switch , the Engine Load is on its highest point - 35PSI
so the car wont start/run
i double checked the MAP connector , everything connected as it should...
what can be the problem?
TIA
Old Feb 23, 2009 | 11:08 PM
alpha's Avatar
Default Re: Problem in AEM EMS - Engine load stuck on 35psi
So you're reading 5v. Triple check your wiring, make sure Map Analog Input is Map Sensor and try another map sensor
Old Feb 24, 2009 | 08:26 AM
Rtype16's Avatar
Did you change the settings in the EMS to tell the computer that it is a gm 3 bar map sensor?
Old Feb 24, 2009 | 09:04 AM
MadScientistMatt's Avatar
I'd measure the voltage at the signal wire on the MAP sensor. If it's 5 volts, there's probably something wrong with the sensor.
Old Feb 24, 2009 | 04:32 PM
Tomdata's Avatar
check the map/wiring
Old Feb 25, 2009 | 06:19 PM
sander's Avatar
2.7(p/t)
Some conversions to V1.19 did some strange things, Alpha is correct, make sure your map input is set to map sensor.
Old Apr 8, 2009 | 06:26 AM
magefa's Avatar
Thnx for the help every1
wiring to the map sucked! a cable was loose...
magefa's Avatar
journeyquest
Jul 23, 2014 02:58 AM
spockeg
Engine Management and Tuning
22
Oct 19, 2009 07:54 PM
hovic
Sep 28, 2004 01:25 PM
CiViC SiR
Jul 7, 2003 02:55 PM
