P28 manual ecu
Old Oct 19, 2015 | 01:22 PM
Monty Williams's Avatar
Default P28 manual ecu
Would like to know any info about this for some reason side of case says stage 1 chipped p28 buti don't see a chip I've compared to some stock ecu pics and only found slight difference but it was on harness side not over where I see pics of chips installed thanks for any response as I just acquired a full donor car and removed everything I needed to swap this d16z6 into my 2000 civic ej6
Old Oct 19, 2015 | 01:34 PM
TheShodan's Avatar
Moderator
Default Re: P28 manual ecu
No info to be told. You have no chip at all. Talk to the individual you bought it from and hash it out.
Old Oct 19, 2015 | 01:46 PM
Thankyou for responding didn't buy got complete swap for free just pulled ecu and what it said so wanted to know what I had to work with b4 I wired it all up into my car no idea why someone wrote this on their wasn't previous owner so maybe a past owner bought it and got screwed...
Old Oct 19, 2015 | 09:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
A stock P28 ECU will run a D16Z6 just fine... you don't need it to be "chipped". All you will need is an OBD-2B to OBD-1 ECU harness plug adapter.
Old Oct 21, 2015 | 08:59 AM
TheShodan's Avatar
Moderator
Possibly. You can run the ECU stock with a jumper harness loom as just mentioned, but if you want "performance", you can't just get a general "chip" and expect magic, unlike what the interwebz tells you.
92lxsleeper
Jul 17, 2009 04:05 PM
Naudlee
Jul 3, 2006 01:23 PM
integracivic94
May 15, 2003 02:24 PM
