P28 capacitor and resistor diagram/layout
I’m sorry guys for asking but I’ve searched for close to two hours now I’m looking to find a capacitor layout diagram for p28 ecus I’ve been doing installs for s300s bbg/pwms and cap replacments for all my local buddies and Honda enthusiasts in my area for a little while now just got a ecu for that I’m cleaning up and doing a bbg install on and he asked me to take a look at vss because he’s throwing a code every time the laptop gets plugged in. Well long story short I would like to have a diagram layout of what cap does what and it’s corresponding board number/location. I’ve looked on my sites and forums and can’t find the diagram at all
so if someone could point me in the right direction it would greatly be appreciated if that’s not something easily found what about the cap location for vss? I plan on running through and making sure the s300 was and installed correctly but I don’t see that being an issue being he bought the ecu off of marketplace put in his build got a base map going and ran the car a few times. He said it’s only when the laptop gets plugged in it throws the vss code but still works on dash.
I appreciate any help and thank you in advance!
Did you solve this? You on Hondata's forums? They may be of help.
Oh... you may be able to help me...what do you use for de-soldering? See my crying shame post above if u wish...
(may have destroyed my p28 trying to remove ic)
