odb0 to obd1 conversion 91 integra ls
Old Mar 19, 2009 | 07:26 AM
91integra_rubio's Avatar
Default odb0 to obd1 conversion 91 integra ls
what is the average cost to convert to obd1 from obd0 and a good place to get all the necessary parts, minus the dizzy.
Old Mar 19, 2009 | 01:31 PM
tilegend's Avatar
Default Re: odb0 to obd1 conversion 91 integra ls
check www.xenocron.com or www.rywire.com for the obd0-obd1 conversion harness and the OBD0-OBD1 distributor harness
they should also have the o2 sensor if not check www.sparkplugs.com and just look up the +92 for the 4 wire o2 sensor
you can keep your old injectors as long as you use the resistor box that should already be on the car.
and then you just need the ecu. check the FS section or ebay.
it should be around $200 minus ecu and distributor.
Old Mar 19, 2009 | 08:41 PM
mtber's Avatar
You can disable the o2 sensor with a chipped ecu :-)
The obd0 to obd1 harnesses run $104, you can buy an obd0 to obd1 distributor jumper to allow you to plug & play an obd1 distributor for an additional $50.
http://www.phearable.net/shoppingcar...sses-c-28.html
Old Mar 26, 2009 | 08:38 PM
240driftkid's Avatar
i just got mine last night, very very easy to install!
$140 for jumper and distributor jumpers
$90 for used dizzy and new cap and rotor
$83 for o2 sensor (i got new)
borrowing a friends ecu..
Old Mar 27, 2009 | 08:38 AM
Spunkster's Avatar
Using Hondata I have successfully used a 1 wire O2 sensor with OBD1 conversion. You just disable the heater and run the single wire into the O2 input.
Old Mar 27, 2009 | 05:53 PM
okay if i get all the jumpers and equipment if i buy an ecu off of xenocron or phearable do i have to solder a bunch of **** or can i buy a basemap chip and then just plug that in.
Faya
Engine Management and Tuning
Feb 16, 2009 07:40 PM
lsvtec hf
Jan 21, 2009 12:02 PM
hi-Powered
Apr 30, 2005 01:28 PM
mrx
Mar 12, 2005 01:06 PM
