Need a quick Look at this .bin file
Old Feb 10, 2012 | 03:54 AM
morbius18's Avatar
Default Need a quick Look at this .bin file
I'm going to be street tuning my motor that I'm rebuilding and wanted some advice on the bin file to see if it is a good start.
Specs:
B16A2
PCT 81mm pistons
2000 ITR camshafts @ valve springs
Ferrea Flat faced valves
KMS TI retainers
295 DSM injectors
255 lph fuel pump
P30 intake manifold ported to 70mm Skunk 2 throttle body
CAI
Hytech replica header
2.5" exhaust
CTR N1 crank pulley
Fidanza lighweight flywheel
Chipped P28 ecu
Ostrich 2
Hulog
Crome pro
AEM UEGO wideband
I had to zip it up because I couldn't upload a bin file.
File Type: zip
Old Feb 11, 2012 | 06:17 AM
morbius18's Avatar
Default Re: Need a quick Look at this .bin file
Can anybody help?
Old Feb 11, 2012 | 09:06 AM
mouab18c1's Avatar
Looks fine, try it out and if it doesn't work well. Then make a new one.
Old Feb 11, 2012 | 12:06 PM
morbius18's Avatar
I was mostly worried about trying it out and breaking something. I was wanting to start with something conservative and tweak from there
Old Feb 11, 2012 | 12:20 PM
mouab18c1's Avatar
Since you have a wideband then you should be able to determine if it's running lean or rich. If you want to be safe at 5-10% fuel across the board.
EusebioSam19
19
Jul 1, 2011 02:05 PM
wannabar
26
Mar 13, 2009 01:07 PM
Senbonzakura
Oct 25, 2004 10:45 AM
Blk98Teg
Apr 7, 2003 09:47 AM
