MAP Sensor Wiring on 1992 Hatch
Old Sep 25, 2008 | 08:32 PM
TopEndTuner's Avatar
Default MAP Sensor Wiring on 1992 Hatch
Ok so I switched shells and my last car was a 1992 hatch as well. The difference is that on my old car the Map came out of the wiring harness and had the typical Yel/Red, white,Grn/Wht wiring but the new one has a separate MAP that is wired straight to the ECU. Has anyone dealt with this issue? I need to wire up My 3Bar map soon somebody give me some insight. And yes I searched but everything links to Hondata's MAP wiring site and its for the other MAP
Old Sep 26, 2008 | 01:18 PM
Default Re: MAP Sensor Wiring on 1992 Hatch (TopEndTuner)
nobody?
Old Sep 26, 2008 | 07:21 PM
mtber's Avatar
Wire the map sensor to the wires running from the firewall to the ecu on your civic....
Wiring diagrams for 3 bar map sensors can be found on http://www.phearable.net/tech
Old Sep 27, 2008 | 06:32 AM
Default Re: MAP Sensor Wiring on 1992 Hatch (mtber)
I would do that but the colors aren't the same and I can't find the correct pin out diagram
Old Sep 28, 2008 | 08:39 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TopEndTuner &raquo;</TD></TR><TR><TD CLASS="quote">I would do that but the colors aren't the same and I can't find the correct pin out diagram</TD></TR></TABLE>
Use a multi-meter to verify what wire is what....
What colors are the wires ?
Yellow is usually always power (5 volts to the map sensor)
Green is usually always ground.
Red or White is usually the signal color...
Old Sep 29, 2008 | 06:38 PM
Alright mine are white, Green/blue stripe, Yellow/green stripe. Anybody gotta clue?
Old Sep 30, 2008 | 07:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TopEndTuner &raquo;</TD></TR><TR><TD CLASS="quote">Alright mine are white, Green/blue stripe, Yellow/green stripe. Anybody gotta clue?</TD></TR></TABLE>
BUMP
Old Sep 30, 2008 | 12:37 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
Red or White is usually the signal color...</TD></TR></TABLE>
Old Oct 4, 2008 | 04:22 PM
intense4thgen's Avatar
i just did one it was white -signal
yellow/red-5 volts
green/red ground
1993 civic si also
Old Oct 4, 2008 | 04:58 PM
Default Re: MAP Sensor Wiring on 1992 Hatch (intense4thgen)
Sweet thanks man I hit it up with a multimeter the other day
HatchMo
Oct 12, 2008 04:46 AM
braindamaged1972
Feb 1, 2007 07:12 AM
SoOHiGH
May 26, 2005 12:46 AM
turbosohcdelsol
Nov 16, 2004 06:06 PM
