Kpro ELD wont log Under 1.4v
Old Jan 4, 2013 | 09:17 PM
93supercoupe's Avatar
Default Kpro ELD wont log Under 1.4v
Kpro green board
Kmanager 3.2.2
EG hatch
stock k20a2
I have the 0-5v from my AEM uego going to E15. With the sensor unplugged, i adjust the voltage offset to match perfect.
It will log anything above 12.3ish/1.4vish (going off memory)fine, but anything under that, it will just stay at 12.3/1.4v even tho the gauge displays 10.0afr.
So i change the gauge with a known good AEM unit, with the same results. I put a meter on the 0-5v output of the guage and add alot of fuel across the map, and i get .2v at 10.3AFR and 2.xx at 14-15 AFR witch seems correct.
I call hondata, and they assure me there are not resistors that need to be removed in the ecu and it must be the AEM units fault.
Any help? Thanks.
Old Jan 5, 2013 | 03:32 PM
Default Re: Kpro ELD wont log Under 1.4v
anyone?
Old Jan 6, 2013 | 11:12 AM
logged again today. still wont go under 1.4v
Old Jan 7, 2013 | 01:10 PM
Fixed by removing resistors r300 and r301.
93supercoupe
Jan 7, 2013 05:36 PM
Freshdot
Engine Management and Tuning
Dec 11, 2012 07:11 AM
CplNet
Jun 17, 2009 02:47 AM
phearable
74
Oct 16, 2007 05:33 PM
EGfastback22R
Feb 16, 2004 04:54 PM
