K swap css to vss help
Old Mar 13, 2026 | 10:00 AM
96Spec Ek's Avatar
Default K swap css to vss help
Im having some trouble getting my speedometer to work. I bought a k tuned all in one converter. Any insight on this is appreciated.
Using rywire k swap harness and hybrid conversion harness with a pnd ecu kpro v4
Old Mar 13, 2026 | 08:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: K swap css to vss help
What ECU are you using ?
Old Mar 14, 2026 | 05:03 AM
96Spec Ek's Avatar
Pnd ecu with kpro v4, I edited my original post
Old Mar 14, 2026 | 07:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
... and what transmission are you using ? The wiring for that device is pretty straight forward, so do you believe that the wiring is correct ? Have you altered the programming in the K-Tuned device ? Lastly, it is not uncommon for people to remove the front mounted speed sensor, accidentally lose the thin washer/spacer that should be installed between the sensor and the trans case, and then re-insert the VSS. The sensor tip makes contact with the gear inside and as soon as you attempt to drive the car, the sensor gets damaged.
Old Mar 16, 2026 | 04:15 AM
96Spec Ek's Avatar
Transmission is a z3, the wiring should be correct as well. It pegs out as soon as I drive.
Old Mar 16, 2026 | 07:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Hmmm... that would suggest that the sensor is working. It is possible that you have interrupted the VSS signal wire too close to the ECU... remember that the wire splits before going into the ECU. Check your sensor output in a datalog and see if the VSS in the data stream is normal (or closer to normal anyway). If so, you have interrupted the VSS signal for the instrument cluster in the wrong place. You might want to tap into the signal wire after the integration plug (some call it the C101 connector). This way, you are getting the signal wire between the ECU and the speedometer itself.
Old Mar 20, 2026 | 07:18 PM
96Spec Ek's Avatar
Thanks for the insight, im going to take a look tomorrow ✌️ ill report back
ap1frankie
Jul 15, 2018 11:40 AM
K20boiZ
Honda Civic (2001 - 2005)
Feb 11, 2008 01:06 PM
