ITR Bin File (Crome)
I was looking for a BIN file for my setup which consists of...
JDM ITR 96 Spec
3 inch AEM CAI
Hytech Rep Header
BCS2 Exhaust
AEM Fuel Rail
AEM ADJ. FPR (what psi should this be set at?)
Stock Cams, Stock Internals
ECU: P28 chipped
I appreciate any help.
JDM ITR 96 Spec
3 inch AEM CAI
Hytech Rep Header
BCS2 Exhaust
AEM Fuel Rail
ECU: P28 chipped
Here was the map given to me by All Motor if anyone else needs it http://www.mediafire.com/?vujwpb3ebb3ece9.
There is not a "stock ITR" bin for Crome.
You can use a stock p72 bin & tune from there.
My suggestion is to get a binary file from a respected tuner/vendor on the forum.
We along with other vendors offer them.
The ignition tables also could use adjusting.
Isn't a P72 map fairly different from a P73 considering an ITR has a higher CR, Larger cams, a factory port, and a different style IM (No IAB's either)?
Jimmynitro
Engine Management and Tuning
Sep 30, 2012 02:13 AM
slowteg550
May 4, 2006 07:26 PM
rice4life
12
Jan 5, 2005 05:27 PM
