Injector Battery Voltage Compensation
Old Sep 19, 2011 | 03:58 AM
alperx's Avatar
Default Injector Battery Voltage Compensation
Hi
What is Injector Battery Voltage Compensation for exactly and technically ?
If I change one injector to another one and dont change the Injector Battery Voltage Compensation, what willl happen ?
Old Sep 19, 2011 | 05:12 AM
tepid1's Avatar
Default Re: Injector Battery Voltage Compensation
Depends on what injector your coming from and going to.
The offset wall compensate for a low or high battery voltage and how the injector reacts to that specific injector type. It's a very valuable compensation tool.
Old Sep 20, 2011 | 06:16 AM
sc_at_QuaifeUS's Avatar
If battery voltage wasn't compensated for, you'd deliver more fuel with s 2.5ms pulse at 13.5 volts than you would at 11.5 or 12.5 volts.
Basically, it keeps fuel delivery consistent even though the supply voltage varies. Since every injector has a different internal coil with various amounts of energy & time required for it to open, an offset table tailored for each injector is necessary for accurate fueling.
Old Sep 20, 2011 | 08:57 PM
alperx's Avatar
thank you very much
MecanicaPR
Jul 6, 2017 09:45 PM
SpokaneSpeed
Engine Management and Tuning
32
Aug 13, 2013 04:02 AM
raverx3m
14
Dec 7, 2012 11:56 AM
alperx
Dec 1, 2011 12:39 PM
Lost Type R
Audio / Security / Video
Sep 20, 2003 05:48 PM
