Hondata S300
Old Jun 27, 2024 | 11:45 AM
Mr. Mike's Avatar
Default Hondata S300
Hey everyone. I'm going to be swapping a b16a2 (1.9L after the stroker kit) into my CRX. It'll be turbocharged with at least 400HP. I want to be able to adjust the boost for normal driving and fun driving. Is The S300 a good choice? Thanks for any input.
Old Jun 28, 2024 | 10:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Hondata S300
It sure is.
Old Jun 29, 2024 | 09:46 AM
2x0's Avatar
2x0
10 Year Member
You should be able to achieve anything you want with it. Can set up boost by gear, and also a switch for hi boost and low boost as long as you have a boost control solenoid setup.
Old Jun 29, 2024 | 10:15 AM
Mr. Mike's Avatar
Excellent! Thanks!
Old Jul 2, 2024 | 09:46 AM
spAdam's Avatar
Loved
Community Favorite
Pretty decent for basic setups, and it's the best of the options available for stock ecu-based systems. Hardest part at this point is finding a decent donor ecu to use and making sure it is properly refurbished with new capacitors, etc.
If you find yourself wanting to add features - Coil on plug, traction control, etc. - They add up fast and you are very quickly in a place where you're better served going for a proper ecu that has all of that built in along with much more modern/faster hardware and much better software too.
Old Jul 2, 2024 | 10:49 AM
Mr. Mike's Avatar
I'll definitely keep that in mind!
Haws
Engine Management and Tuning
11
Oct 31, 2014 06:14 AM
Reego.
Mar 6, 2008 10:22 PM
h22a193
May 4, 2005 04:51 AM
redboost10
Oct 15, 2003 11:18 AM
