High altitude tuning question
Old Sep 29, 2011 | 08:36 AM
GagnarTheUnruly's Avatar
Default High altitude tuning question
I'm street tuning my B18C with Blox A cams, and I feel like I've had to pull a lot of fuel everywhere on the map to get my AFRs where I want them.
I'm at a little over 3000 feet, and my question is: does tuning for altitude usually involve changing the fuel map? Or does altitude only affect where I will be on the fuel map for any given throttle position?
For example at WOT I max out at about 880-900 mbar. Will my fuel value at 900 mbar be the same as a car at sea level, or will it be lower? If not, I need to figure out what's going on...
Old Sep 29, 2011 | 09:24 AM
sc_at_QuaifeUS's Avatar
Default Re: High altitude tuning question
You lose ~3% per 1000' due to the decreased oxygen content. So 900 mbar of air at 3000' has ~9% less oxygen than 900 mbar of air at sea level.
This is what a baro. sensor is intended to correct.
With a speed density system, if a baro sensor is present and the table for it is correct, you could drive from Denver to New York with consistent A/F ratios without adjusting the primary fuel map.
Hope that helps.
evlgsr
Engine Management and Tuning
Jan 9, 2017 01:27 PM
iwannarace
Mar 31, 2015 04:40 PM
FSA
Honda Civic (2006 - 2015)
Jul 7, 2010 06:24 PM
97grnrs
Dec 8, 2007 12:46 PM
Sinner
Jun 15, 2006 09:54 AM
