Help p2646 qnd p0340 engine codes on 2005 pilot
Old Aug 29, 2024 | 04:30 PM
Skyguythelegend's Avatar
Default Help p2646 qnd p0340 engine codes on 2005 pilot
So I'm at a bit of a breaking point right now, my pilot broke down a little while ago, I've had the p2646 code for a while, it would turn on while driving sometimes but wasn't really a problem because my ivtec would still activate even though the code says it's stuck off. I heard that my car should be in limp mode but it's had no problem getting up to 100 mph and high rpms. Recently I had p0340 come on and I scanned it and it told me it was my camshaft position sensor that went out. I cracked the timing belt cover open on bank 1 by the radiator and had someone crank the engine, and the crankshaft turned with the serpentine belt but the camshafts did not turn. I also loosened the serpentine belt, took off the top pulley so I can access the camshaft sensor and it's hard to access the bolt holding in the sensor, I need help diagnosing what happened, the light came on at 4k rpms and at 70mph, it just up and died and sputtered. No smoke from the hood either.
Skyguythelegend
Aug 29, 2024 04:33 PM
MacMade
Sep 14, 2020 12:09 PM
Urbina1994
Oct 31, 2017 04:19 PM
depoladim
Dec 11, 2012 03:54 PM
irmr2
Oct 24, 2006 02:39 PM
