Help, Install Microtech lt8s and does not work the dashboard?
Old May 19, 2010 | 04:40 PM
0487erasmo's Avatar
Default Help, Install Microtech lt8s and does not work the dashboard?
Hi, guys. I need a little help, recently installed by my civic 93 a Microtech LT8 ECU-S. The problem is that none of the dashboard works. Neither temperature, or gasoline, or revolutions, nor mph. Just disconnect the wiring of the engine, from where the two plug, but you must connect all the sensors that are supposed to work with the dash and is mounted original computer and nothing works. Thanks
Old May 20, 2010 | 08:35 AM
THC07's Avatar
Default Re: Help, Install Microtech lt8s and does not work the dashboard?
ugh! how much did that thing cost? 1300$ ?
I dont think anyone around here is gonna know much about that.
cant say I have ever seen anyone using a mircorech ecu.
did you look at http://www.microtech-efi.com/support/setup_tips.html ?
also check out the wiring diagram page too be sure you have it all correct.
after you get it working please send testimony. they make it sound like some kind of amazing easy way to tune, Im a little doutful tho. looks like a piggy back to me.
Old May 22, 2010 | 01:54 PM
0487erasmo's Avatar
Yeah, cost me something. This well-mounted, because the wiring of the computer consists of several cables, is not so complicated. It is well good for tuning, here in Puerto Rico is widely used in racing cars. The problem is that how it works with other separate wiring, disconnect the rabbis of the original engine and just leave the plug connected sensors mile mark speed and temperature and not working
cabledude4619
Audio / Security / Video
Mar 6, 2012 05:51 PM
0487erasmo
May 22, 2010 01:51 PM
92hatch_cx-t
May 10, 2006 03:06 AM
ringgold
Jul 31, 2004 07:18 PM
