Harness problem????
I have an issue with my hatch, but I think the problem is with the electric harness, sometimes when I drive the car loss power for around 3 or 4 seconds, It looks similar of lack of fuel or malfuntion of the fuel pump. I changed fuel filter, spark plugs, fuel pump, cleaned injectors, I used a friend's P28 ecu but the problem persits B16A is my engine with P30 ecu
I think it is an electric problem, if someone knows what could be the problem it' ll be very helpfull for me. Thanks!!!! |
Re: Harness problem????
Any check engine light codes?
Nop, car runs great but this problem happens in low rpm. A friend said that could be a loose wire in the ignition module.
Engine stall in low RPM? And after you push some break or play with steering car run back normal? Try check for check engine code even there no CEL. There some issue got ELD code 20 without check light.
Hi Madji
The problem looks like the fuel pump malfunction, I dont push break when the problem happens I just increase the speed and the power come back. |
| All times are GMT -8. The time now is 07:29 AM. |
