few crome Pro questions
Old Mar 8, 2012 | 06:55 PM
uvamosk's Avatar
Default few crome Pro questions
Hey guys,
I'm about to go to dyno again and wanted to ask a few questions.
To sync Timing with Crome I just jump service connector and set timing on crank pulley to middle of the 3 lines correct? This puts it at 16.5 degree's.
The base timing tables under advance options should I leave them or make them all 0 so they do not interfere with my timing maps?
Should I leave the IAT and ECT compensation tables alone and just tune the fuel/ignition maps and let the IAT and ECT compensation run its course?
Thanks and if you have any tips for tuning with crome just let me know and also if their is anything I should double check or look out for.
Thanks again ^_^
Old Mar 10, 2012 | 10:27 AM
2000CTRSi's Avatar
Default Re: few crome Pro questions
Zero out all the trims that can change ign, and se the idle area to desired timing value and use you light.
prodjay10
May 6, 2016 10:43 AM
brokenojoke
Engine Management and Tuning
Jun 14, 2008 09:50 PM
bazookatooth
Apr 23, 2005 11:56 PM
flyrice
Jan 3, 2004 11:44 PM
