EK3 high negative fuel trims
Old Oct 30, 2022 | 01:24 PM
dipar's Avatar
Default EK3 high negative fuel trims
I have a Civic EK3 with a d15z6 engine (EDM) and been trying to figure out why I have such negative fuel trims for months now. Here are my logs (from Hondash):
What was done/replaced:
- All filters
- Fuel injectors
- FPR
- Cleaned TB
- O2 sensor
I'm running out of ideas. Any help?
Old Nov 1, 2022 | 06:07 AM
countrynoob's Avatar
From: Whats Up MN!! But still the middle of nowhere...
Default Re: EK3 high negative fuel trims
https://gtc.ca/blog/long-term-fuel-t...rim-fuel-trim/
Old Nov 1, 2022 | 09:45 AM
dipar's Avatar
I've done my research and checked those possible causes, except the cat. But I assume that would cause other symptoms.
Old Nov 2, 2022 | 01:17 AM
I just wanted to confirm, are you throwing a code? Also, you may have to watch videos of how technicians use those data and how those data change over time to properly diagnose problems. I use to watch "Shroedinger's Cat" on YouTube, the free channel, to chase a lean code on my Rav4 because replacing parts was not in my budget at the time. Added with the fact with that particular car, the TCM throws a code in conjunction with any engine code, so cruise control was disabled.
Old Nov 2, 2022 | 12:32 PM
dipar's Avatar
No codes. I disconnected 2 hoses, one at a time and watched the fuel trims. When I disconnected the breather coming from the valve cover, the fuel trims didn't change. When I disconnected the PCV hose, the fuel trims went from -18.0 to -16.4, which indicates some blow-by, but not the main cause.
Fresh_Si
Apr 2, 2007 07:05 PM
teamvirus
22
Dec 22, 2005 05:03 PM
pentaq
May 2, 2005 03:05 PM
n2oisfun
Mar 1, 2005 07:10 AM
DC2NING
Jan 27, 2004 04:38 PM
