Is this catastrophic? It's a P06-L00 out of my 98 integra with a gsr head on a b18b block.(side note, I bought the car already boosted by previous owners and it does run but the wideband shows it runs really lean, idk if it is accurate). I was about to notch the ecu case to install my BMulator and found this.
Sorry That this is slightly Off topic - How did the BMulator install go? and Did the kit come with some sort of instructions? looking to pull the trigger on one asap, just not sure of the Data logging situation, if its intergraded now or still requires you to connect wires to the board from the port slot etc
