Dizzy obd2B problem
I just swap a h23a blue top vtec engine into my 97 prelude . Everything is perfect , run perfect . Except that the swap came with a obd2 B dizzy. I rewired it to my obd2 A harness but here is the problem. An obd2 B dizzy doesnt have a RPM out Blue wire to send the signal to the cluster. Instead in an obd2 B car they used from the ecu a rpm output to connect the cluster.
Since my setup is obd2 A from my 97 prelude How can i connect my Blue wire ( RPM signal )
Do the RPM is generated from the TDC + or something. I tried CKP + since the wire was blue but no luck , its not it.
There is the only thing missing from my swap that dawm rpm blue wire.
Where do i need to tap this wire to ?
an other thing , some of you will probably say how dont you use the dizzy i had from my old h22 engine that came from the car .
I couldnt since this car was using the CKP/TDC from the oil pump like an external crank angle sansor, it is not integrated into the obd2 A dizzy with external coil ... JDM dont use such thing . its all integrated into the dizzy.
So i rewire the CKP/TDC from the obd2 b dizzy into the connector that was doing to the crank angle sansor ... work pefect.
I rewired the cylinder possition from the obd2 b dizzy to the old dizzy connector .. work perfect ...
Also connected the icm signal .... and power....
Missing blue rpm wire...
thats almost it !
thats almost it !
boarderkid998
Mar 30, 2010 05:42 PM
