D16y8 set at 21 degrees?
Hi all! I really need some help I have never fully understood how to properly advance my timing, and use my advance dial on my gun I’ve read posts after post and still need some clarification. Here’s my situation....
Re: D16y8 set at 21 degrees?
21 degrees not at idle! Its on light throttle or wot. Idle is round about 14-16° degrees at idle.
need a advance light to do that...set your advance light to +5 and shoot for the factory 16* mark. 16+5 = 21
I never used an advance light so thats about as much as i Know. Not sure why your tuner wants 21 tho he should use 16* and make timing chaged in the tune IMO |
See that's what I'm saying 21 just seems way to high I've never used the advance dial I'm hella confused still.. I think I'm going to let him install the p28 and time it.. I swear... But I think I get what you're saying with the +5, basically get it set at 16 degrees then turn the dial to 5 which would add 5 degrees? Or now you're making me think maybe I'm supposed to spin the dial to 21 ahhhhh nevermind I'm still lost lol
pretty sure you add the number to whatever your shooting, so if you set to 21 you need to shoot the 0* timing mark, so it just adds onto what number you already have available
The fact that your tuner wants 21* bothers me tho, have you talked to any other tuners in your area? |
Originally Posted by 2kdrift
(Post 51721045)
D16y8= 12 degree base timing |
