Cylinders flooded with fuel
Old Dec 29, 2015 | 11:24 AM
Dundee's Avatar
Default Cylinders flooded with fuel
90 ef si b16
Wanted to see if anyone has had this issue and would like to give me some advise.
Engine is flooded with fuel #2 only. Have spark , good compression, no cel codes. Car turns on but real hesitant and spits good amount of fuel through exhaust. No power at all. Timing is good, car ran fine just happens from one day to another
Old Dec 29, 2015 | 11:49 AM
bluenc-87's Avatar
Default Re: Cylinders flooded with fuel
I doubt it's fuel coming out ur exhaust unless u talking about ur exhaust ports. If so ur plugs will be soaked in fuel.
Old Dec 29, 2015 | 11:52 AM
Dundee's Avatar
It's fuel. Not burning coolant at all. I'm guessing it has to do with wiring but just checking to see if anyone has had this issue before. I've swapped out injectors and same problem with the same cylinder. Stuck open only at plug #2
Old Dec 29, 2015 | 12:08 PM
bluenc-87's Avatar
Your distributor is not retard? You have correct heat range plugs? Correct fuel injectors rating for ur build? Correct fuel pressure? Correct tune for ur car? No missing injectors gaskets?
some things i can think off
Old Dec 29, 2015 | 03:33 PM
v4lu3s's Avatar
RTFM
Un plug that injector and see what happens...
Old Dec 30, 2015 | 02:29 AM
7rrivera7's Avatar
Try another ECU if available or move your ECU to another car
Old Dec 30, 2015 | 03:29 AM
Muckman's Avatar
Moderator in Chief
swap problem injector to a new cylinder. see if problem follows injector.
Old Jan 3, 2016 | 05:38 AM
Dundee's Avatar
Found out issue. After market fuel pressure regulator(aem), opened it up and they have a rubber gasket in there. Gasket had a minor tear which was letting gas through the vacuum side of the regulator. Which lead to the intake and so on out the exhaust
Old Jan 4, 2016 | 08:06 AM
Dundee's Avatar
Fuel pressure regulator gasket
Old Feb 26, 2016 | 09:00 PM
motoxxxman's Avatar
Originally Posted by aliagrace
This is because of loosening of valve cover gaskets . On that engine, the spark plug tubes go down through the top of the valve cover. The tubes have tube seals that come with the valve cover gasket set. This is not a big issue . The valve cover gasket is easy to change. Also, valve cover and cylinder head cover are interchangeable terms for the top cover of the engine.
wow. just, woooow. do you have any idea what you're talking about? did you read anything in this thread at all??
Old Feb 28, 2016 | 12:52 PM
VegasInvasion's Avatar
I'm Huge In Japan
^lololl
Old Feb 28, 2016 | 04:08 PM
rossyrossb18a's Avatar
SERIOUSLY?!?!?!?!?!?!?
CRXWOLSKI
17
Jan 10, 2008 03:11 PM
unlocked
Mar 15, 2005 09:44 AM
EKB18BPR3
Nov 23, 2004 12:43 PM
cobrahandler
May 19, 2004 12:54 PM
b16awarrior
28
Sep 20, 2002 05:26 PM
